Context Ui minimiztion
is there no way to minimize this part similer to all other sections of the UI, While i notice its possible to select similer to other sections, you cant drag and drop to maximize or minimize
It’s possible to hide it using the arrow on the bottom right.
A workaround is to change the system zoom or use the browser zoom:
been minimizing, just wondered, if simile rto other section, like maills vier, could also be resized s well
