Connect to Zabbix through reverse proxy
NethServer Version: 7.7.1908
Module: Zabbix
When I access the zabbix with IP inside my network https://192.168.1.14/zabbix then I have no problem to login and work with my zabbix server.
But when I trying to access it from my domain that go through a reverse proxy https://subdomain.domain.se and then trying to login it say
You are not logged in
  • You must login to view this page.
  • If you think this message is wrong, please consult your administrators about getting the necessary permissions.
I running a nethserver with web server as reverse proxy.
Hi CJ,
Maybe…
Access for green and red networks for ports 10050 and 10051
# config set fw_zabbix service status enabled TCPPort 10050,10051 access green,red
# signal-event firewall-adjust
Verification
# cat /etc/shorewall/rules | grep 1005*
ACCEPT  loc     $FW     tcp     10050
ACCEPT  net     $FW     tcp     10050
ACCEPT  loc     $FW     tcp     10051
ACCEPT  net     $FW     tcp     10051
# config show fw_zabbix
fw_zabbix=service
    TCPPort=10050,10051
    access=green,red
    status=enabled
Michel-André
@cazz
Is Zabbix running on your NethServer?
Reverse Proxy has two modes: Folder-Redirect (eg /zabbix/ ) or Domain-Redirect (eg zabbix.mydomain.com ).
I use both forms of redirect with the Reverse-Proxy in NethServer, depending on target. I also let NethServer (usually) handle the SSL via LetsEncrypt.
However: If your NethServer is running Zabbix (As per available module) AND also happens to be your reverse-proxy, then: No Reverse Proxy is needed.
Simply access your Nethserver as follows:
https://nethserver.mydomain.com/zabbix
Note: I use variants as:
https://intranet.mydomain.com/zabbix
these work well too!
@michelandre
I think he’s trying to access the Web Front-End (GUI), not open the Zabbix Ports to the Internet or LAN.
Hi André,
I agree.
Michel-André
@michelandre
yes that is the GUI I trying to access :slight_smile:
@Andy_Wismer
Yes I use domain-redirect on my proxyserver
My network is build so with a proxyserver (nethserver) takes care of all traffic that come from my domain and also take care of my cert from LetsEncrypt. It send the user to the right server I have on my server park dependent on what domain and subdomain it use. All my service works like it should like guacamole,web server, webmail and some other service.
@cazz
Try using folder redirect, should be sufficient for Zabbix…
@Andy_Wismer
Why not, can be interesting to see if it works.
Going to try that tomorrow, have to read a little about it because I have never done that in nethserver and not sure how to do that.
@cazz
Is Zabbix running on the same NethServer as your Reverse-Proxy?
Reverse proxy with folder only work if the folder isn’t in use on that server, eg /zabbix…
@Andy_Wismer
No every system have it own Nethserver.
@cazz
Reverse Proxy should still work…
I don’t assume you have several Zabbix servers (one, well planned, is enough!).
So the /zabbix/ would only be available on the Zabbix server, not on the Reverse Proxy.
Note: The Zabbix Agent does not use a web interface…
See also here:
https://docs.nethserver.org/en/v7/ui/ProxyPass.html
mm I have done that too so I have to dig in a little in this weekend to see what is wrong.
@cazz
I’d try
  1. allow http & https on the zabbix server.
  2. use an unencrypted connection from your reverse proxy to your Zabbix server. quite often differing SSL certs ARE a bigger issue than expected…
Hi again
This is a old topic but still same problem.
Last time I gave up and stopped using Zabbix. But a friend of mine wants to use it and unfortunately I’m stuck in the same place again. But I have found something that might shed some light on the problem. When I activated the guest account on Zabbix, I can log in but it logs in as a guest so it seems like the proxy doesn’t understand that it is an account it is trying to log in but as a guest account.
So it seems I need to add something to the config file for proxy but not sure what.
