ibinetwork
(Rafael Tavares)
May 20, 2020, 5:11am
1
Hello,
I run yum update today and have a conflict with new dahdi-tools packet on EPEL repository
epel/x86_64/prestodelta | 1.7 kB 00:00:00
(1/2): dahdi-tools-2.11.1-16.el7.x86_64.rpm | 329 kB 00:00:00
(2/2): dahdi-tools-libs-2.11.1-16.el7.x86_64.rpm | 33 kB 00:00:00
Total 1.8 MB/s | 362 kB 00:00:00
Running transaction check
Running transaction test
Transaction check error:
file /usr/lib64/libtonezone.so.2.0.0 from install of dahdi-tools-libs-2.11.1-16.el7.x86_64 conflicts with file from package libtonezone-2.11.1-2.4.gc2fbe3d.ns7.x86_64
Check repository or help to solutions.
Thanks!
giacomo
(Giacomo Sanchietti)
May 20, 2020, 7:02am
2
Indeed you caught a conflict with EPEL, do you have freepbx installed?
Could you please post the output of:
rpm -q --whatrequires libtonezone
rpm -q --whatrequires dahdi-tools
Hi there!
I have the same problem here.
[root@server ~]# rpm -q --whatrequires libtonezone
freepbx-14.0-8.ns7.noarch
[root@server ~]# rpm -q --whatrequires dahdi-tools
Yes, I have FreePBX installed and running.
ibinetwork
(Rafael Tavares)
May 20, 2020, 2:36pm
4
Thanks you for fast response
ibinetwork
(Rafael Tavares)
5
I see issue open! Thank you for help!
Stll0
(Stefano Fancello)
May 20, 2020, 4:17pm
6
@ibinetwork could you try this package https://github.com/NethServer/freepbx/pull/4#issuecomment-631566449 ?
yum update http://packages.nethserver.org/nethserver/7.8.2003/autobuild/x86_64/Packages/freepbx-14.0-8.11.pr4.ga31c5c2.ns7.noarch.rpm
mrmarkuz
(Markus Neuberger)
May 20, 2020, 9:31pm
8
Installation worked on a test VM.
yum install nethserver-freepbx http://packages.nethserver.org/nethserver/7.8.2003/autobuild/x86_64/Packages/freepbx-14.0-8.11.pr4.ga31c5c2.ns7.noarch.rpm
Same error here (in a Enterprise installation)
giacomo
May 21, 2020, 7:46am
10
ibinetwork:
Bad news!!
You probably didn’t have epel
repository enabled.
Yes, but it doesn’t affect automatic update. The problem on Enterprise/Subscription should pop out only if you force the update after cleaning the metadata.
The package is now in testing and should fix the problem (I’ve already tested it in a couple of machine).
@ibinetwork @PCXLan.es could you please try it? The test command (only on NS 7.8) is:
yum --enablerepo=nethserver-testing update freepbx
ibinetwork
(Rafael Tavares)
May 21, 2020, 12:02pm
11
Its ok, update sucessfully! Thanks
giacomo
May 21, 2020, 12:19pm
12
Thank you to you for reporting and testing!
The package has been released and will land soon to all mirorrs.
We are going to release also the fix for 7.7 to not block those who are not willing to update to 7.8.
