I’ve configered a transparent ssl-proxy as nethserver V7-beta 1. Now I have to work with a banking signature stick and there are several adresses, networks and ip-ranges which schould not be rooted through the proxy.
By this I’ve seen that I can’t add an ip-range to sites without proxy.
It would be nice too, if there is a way to combine the ip-ranges, hosts and CIDR’s to one object, because in this case you have only to add one object for bypass to the proxy settings.
We just implemented Squid bypass using domains.
Would you like to try it?
yum --enablerepo=nethserver-testing update nethserver-squid
Check this out:
Hi Giacomo,
I didn’t had much time the last weeks, so sorry for my late response.
Of cause I will try it. I hope the next week I’ve enough time. You will hear from me.
