A lot of SOGo users would like to move from the GNUstep to /ect/sogo.conf configuration (like me) also sogo-tools seems to rely on sogo.conf.
De dev team probably does this in no-time, but they are busy with more imported stuff.
Moreover it isn’t just making it, testing it takes a great deal of time!
I am a novice in nethserver/sme/centos and even perl, but with some help we should pull it off!
Yes off course, just suggesting an head on approach;
first design a good expanding template; test this an then commit and /or build RMP.
I know how to build dpkg’s, i’ll guess (in time) rpm too
I suggest adapting the current template output from the GNUStep DB format to the sogo.conf format. They seem very similar and perhaps few steps are required:
Remove the nethserver-sogo-gnustepsetup action. It expands the sogo-config template and pipes its output into GNUStep DB, so we no longer need it. Take note of the events that require it.
Rename sogo-config template dir to /etc/e-smith/templates/etc/sogo/sogo.conf. Bind it to the same events of the above action.
Adapt 90expand_conf, begin-template, end-template fragments to the sogo.conf format
# at https://dev.nethesis.it/projects/nethserver/wiki/NethServer
# original work from http://www.contribs.org/development/
# Copyright (C) 2013 Nethesis S.r.l.
# http://www.nethesis.it - support@nethesis.it
/* 10 Database configuration (mysql) */
// Here comes mysql
/* 20 Mail */
SOGoDraftsFolderName = Drafts;
SOGoSentFolderName = Sent;
SOGoTrashFolderName = Trash;
SOGoJunkFolderName = Junk;
SOGoIMAPServer = 'localhost';
SOGoSieveServer = 'sieve://127.0.0.1:4190';
SOGoSMTPServer = '127.0.0.1:587';
SOGoMailDomain = havak.lan;
SOGoMailingMechanism = 'smtp';
NGImap4ConnectionStringSeparator = "/";
The DB entries of folders /Sent/Drafts/Trash should move from Sogo to dovecot DB record;
Sogo should not define those folder names, imap sever should.
This would open the way to force use unified of special folders by auto = subscribe those folders IF a value is given in the dovecot db record. They can be any value (language) you want, migration not taken in account.
haven’t changed the init script, the template has to be expanded manually: expand-template /etc/sogo/sogo.conf
for testing you should (re)move /var/lib/sogo/GNUstep/Defaults/sogod.plist
(which can be restored with: signal-event nethserver-sogo-update)
They can be left out. It just a “EOF”; there is a linefeed at the end and i don’t like a empty line at the end.
Thinkerd with AD’s before, after lots a frustrations I’d promise not to engage it again. Maybe iI.ll wil to get the sogo.conf complete.
Before i’ll try I try a Question:
Why are the GNUStep template’s concstucted to expand both AD- usersources and LDAP-group-/usersources?
Or should there be a “ if not $smb{ServerRole} = ‘ADS’ ; return nothing “ in the LDAPgroup-/usersources?
IIRC they should be mutually-exclusive and - yes - the condition is ServerRole = ADS. We should take into account the fact that in NS v7 this part could change due to Samba4 integration. I suggest to not waste too much time on this!
OK, noted. rewriting your GNUStep template(s) i’d did the AD part too. Didn’t “commit” to it becaurce it isn’t tested; in theory it shuold work (but we heard that before )
Till now it wasn’t that hard. Last week had some time on a vacation (enjoying the snow and food in your lovely Dolomites) to read in to Neth-/SmeServer and perl. It still has to be proven feasible.
Stupid question, but where do you open a PR?
Reading the above ill opt to merge group_source_ldap and user_source_ldap into one template snippet and add a condition “not ADS” for expansion.
