[root@service collectd restart
Parse error in file /etc/collectd.d/sensors.conf', line 163 near‘: syntax error, unexpected $end, expecting EOL
yyparse returned error #1
configfile: Cannot read file `/etc/collectd.d/sensors.conf’.
Unable to read config file /etc/collectd.conf.
Error: Reading the config file failed!
Read the syslog for details.
not restarting due to configuration error
I’m not sure that my Sensor “coretemp-isa-0000” is correct or not ??
The lines between <Plugin “sensors”>… exclude some sensors that on my system are present but not connected.
The names are taken from the /var/lib/collectd directory.
