Collabora Wopi Key
Module: Nextcloud Collabora
Hello. I want to install collabora with a subdomain and request a let’s encrypt certificate ,i go to the nextcloud settings all is ok.
But when i’m want to edit a document i have this error :
Unauthorized WOPI host. Please try again later and inform your administrator if the problem persists
I have write my subdomain on the settings but nothing change. What we need to write ? Or maybe a config file ?
i have install the app from the webui
Collabora and Nextcloud get preconfigured when you enter the CODE server host name in the NS8 Nextcloud settings:
Ok. I dont sée that on the settings of nextcloud.
Now i have setup this
i go to nextcloud settings application and in thé wopi settings need to be blank ?
Because i have test with or without and same error.
Maybe uninstall collabora you think ? And plugin nextcloudoffice ?
Did you install Collabora from the Software Center?
It should work with blank wopi settings.
Yes i have install from the center software.
Can we verify the config file maybe ?
Where can i found them ?
Or maybe reboot.
Maybe something went wrong at installation, did you already try to reinstall?
The config file for instance onlyoffice1 can be found in
/home/onlyoffice1/.local/share/containers/storage/volumes/onlyoffice-etc/_data/local.json
Onlyofice local.json to compare/verify
  "services": {
    "CoAuthoring": {
      "sql": {
        "type": "postgres",
        "dbHost": "localhost",
        "dbPort": "5432",
        "dbName": "onlyoffice",
        "dbUser": "onlyoffice",
        "dbPass": "onlyoffice"
      "token": {
        "enable": {
          "request": {
            "inbox": true,
            "outbox": true
          "browser": true
        "inbox": {
          "header": "Authorization",
          "inBody": false
        "outbox": {
          "inBody": false
      "secret": {
        "browser": {
          "string": "EHAZxfpa8yQbmjDNfmkGXQksRFdo4WA"
        "inbox": {
        "outbox": {
        "session": {
      "requestDefaults": {
        "rejectUnauthorized": false
  "rabbitmq": {
    "url": "amqp://guest:guest@localhost"
  "wopi": {
    "enable": false,
    "privateKey": "-----BEGIN PRIVATE KEY-----\nMIIEvQIBADANBgkqhkiG9w0BAQEAASCBKcwggSjAgEAAoIBAQCbOMLj8YronoD7\nHro2swHLVmzV7wchGXcH5TVXA5lmCrNiCFOxUZvsTSdRlSgUfyeehZ5fgItDTrtE\nMyM1xLaPyfAb3nBmFCHOLO+EGwMHS5vVrB6w/oh0Zous/jO3qtPUD4lnaxUTOQP/\nFsBVlJuImT1ttKHPhhEkG5IwMQavxtlCmOCVosJfTP3xpV7FdXExnRkTpLgaVdM6\nr20vVAkkAKTnvl1AP8pYwFXASkeqLwGlQGTrUE9lC/25eKOD6SyOTEXP/oEhkoNl\nnJaU7O9zsTMR7pIQU+eYRRQInbycgP3LP27G4wJrV9nVyIRooeUFdPH8ifc8usLn\n+BLFEwTtAgMBAAECgf8+tsSzYzBni4CGmQLQwvrmeT26BNpes3PQ4FE71cvNhUBx\nmKSwY+sVLn5J3BBn0F1D2QyZKKUGMVpvhnpPXCXYurJwOhGukbRIW7aVHrNxq8XG\nVfCaPFrwSbys18u94wWoN21P39TBENltUgNfWqyc3W+WtVAhh4uJ+OUSYgfRlV3/\n1zbB06PR0PvBSFP46RqOf3DNGXuDOFI2C+4wSgX2PSLrtITGrvxm9PRSIt7JZ9eA\n4qfYR75LUbv6YY5GiiVe3hSyo+hUgSMR1WdSDbvGJmHPKk4bDOXWu5EtgWLV0eRJ\nikivAty2Ih3LqFFZT3VWpxK1VhtaZbLQWTlGqrECgYEA1PYDunUsXu+6i7hegeSl\n5faQwfzSRspjBdkinZu/0tceOtdy+O8MfCprV3/wmLTX4x4jkCIGbuEetdICAQAr\nbo7aj06KhvFsBuEQmM1fxSXYTkpbtvsYXuswT/C0zDOdRF/t75qyJugxfVSJBcp+\nyT7Bmx6giwFcKMv6fjTdPmUCgYEAupd75uK5pWE3APcHsyjkAjphgcl/TiJ7DLo1\nja0Yn0C+lahsT2YHapvKjGtjJEwgSbEKvN65aOppxfpADwdTqnDIwCk1VL70BvUO\nmaMqgihdjmO3eDYuhAgQbFY694hQ6rpAU/3r/oblAFh1wjKSYUU0NUnSJiEPO0Et\nMF6bH+kCgYEAw6KBCFBOA6S8vVAQ2cjfsmMQ1nRYA5o23496YklLLfhal/mGcDLC\nSGp7k7U/pDk1vjnYt7baLA/4s1UKbDroqzbmhxHC5nZwI92r7oN0gFrk2/8pQ+5l\nlAUAq99XZ+PejIqHvT5ifKV/mUAIZF6CnINfPg4js677J6tDIZ+Uw5UCgYEAnG9e\naI9TN60OcVeqc/FnX9rUXvyxJ6/O3DfNqE8kIngkkNJYpCSVOTMOGLX7s7XDKCUv\nLHPKnIRTU7FgPXlWEsJl/H1QAhHqA18282YRwHfZIATIEBfU3crpAfs1iswVkwW9\n4u0zCvzLR4PijoLZqIVdpQOUFXWIEJSvLytSAOkCgYEAraoAZmD6yBYMlimcXWp+\nMkWC1p2KO6JlYr39/Hjwgp2BqORwbUWX3DS61xdcE4Un/rt65Uz57wAFef5RXS9a\nWTeXNGafDfoGCeku9fOHmf/pNCPiULCEtmBoT5ljfdz/3GdeWL/wn7Kp+eQg/5Ir\nBfJoR0qoHqbs0aZCT49ews8=\n-----END PRIVATE KEY-----\n",
    "privateKeyOld": "-----BEGIN PRIVATE KEY-----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\nBfJoR0qoHqbs0aZCT49ews8=\n-----END PRIVATE KEY-----\n",
    "publicKey": "BgIAAACkAABSU0ExAAgAAAEAAQDtBBPFEvjnwro894n88XQF5aFohMjV2VdrAuPGbj/L/YCcvJ0IFEWY51MQku4RM7Fz7+yUlpxlg5Ihgf7PRUyOLOmDo3i5/QtlT1DrZEClAS+qR0rAVcBYyj9AXb7npAAkCVQvba8601UauKQTGZ0xcXXFXqXx/UxfwqKV4JhC2cavBjEwkhskEYbPobRtPZmIm5RVwBb/AzkTFWtniQ/U06q3M/6si2Z0iP6wHqzVm0sHAxuE7yzOIRRmcN4b8MmPtsQ1IzNEu05Di4BfnoWeJ38UKJVRJ03sm1GxUwhiswpmmQNXNeUHdxkhB+/VbFbLAbM2uh77gJ7oivHjwjib",
    "publicKeyOld": "BgIAAACkAABSU0ExAAgAAAEAAQDtBBPFEvjnwro894n88XQF5aFohMjV2VdrAuPGbj/L/YCcvJ0IFEWY51MQku4RM7Fz7+yUlpxlg5Ihgf7PRUyOLOmDo3i5/QtlT1DrZEClAS+qR0rAVcBYyj9AXb7npAAkCVQvba8601UauKQTGZ0xcXXFXqXx/UxfwqKV4JhC2cavBjEwkhskEYbPobRtPZmIm5RVwBb/AzkTFWtniQ/U06q3M/6si2Z0iP6wHqzVm0sHAxuE7yzOIRRmcN4b8MmPtsQ1IzNEu05Di4BfnoWeJ38UKJVRJ03sm1GxUwhiswpmmQNXNeUHdxkhB+/VbFbLAbM2uh77gJ7oivHjwjib",
    "modulus": "mzjC4/GK6J6A+x66NrMBy1Zs1e8HIRl3B+U1VwOZZgqzYghTsVGb7E0nUZUoFH8nnoWeX4CLQ067RDMjNcS2j8nwG95wZhQhzizvhBsDB0ub1awesP6IdGaLrP4zt6rT1A+JZ2sVEzkD/xbAVZSbiJk9bbShz4YRJBuSMDEGr8bZQpjglaLCX0z98aVexXVxMZ0ZE6S4GlXTOq9tL1QJJACk575dQD/KWMBVwEpHqi8BpUBk61BPZQv9uXijg+ksjkxFz/6BIZKDZZyWlOzvc7EzEe6SEFPnmEUUCJ28nID9yz9uxuMCa1fZ1ciEaKHlBXTx/In3PLrC5/gSxRME7Q==",
    "modulusOld": "mzjC4/GK6J6A+x66NrMBy1Zs1e8HIRl3B+U1VwOZZgqzYghTsVGb7E0nUZUoFH8nnoWeX4CLQ067RDMjNcS2j8nwG95wZhQhzizvhBsDB0ub1awesP6IdGaLrP4zt6rT1A+JZ2sVEzkD/xbAVZSbiJk9bbShz4YRJBuSMDEr8bZQpjglaLCX0z98aVexXVxMZ0ZE6S4GlXTOq9tL1QJJACk575dQD/KWMBVwEpHqi8BpUBk61BPZQv9uXijg+ksjkxFz/6BIZKDZZyWlOzvc7EzEe6SEFPnmEUUCJ28nID9yz9uxuMCa1fZ1ciEaKHlBXTx/In3PLrC5/gSxRME7Q==",
    "exponent": 65537,
    "exponentOld": 65537
  "storage": {
    "fs": {
      "secretString": "mW64T5VEK11Spf0xVpf"
Yes, please try it as it restarts the services.
Ok il will try this night when nobody works and i say you
