NethServer Version: 7.6.1810
Module: Collabora 3.3.6 , Nextcloud 16.01
Hi, i’m try to use collabora but i run in to an error.
I installed nethserver in a VM, then a installed nextcloud and finally collabora.
N.B. I need to use an Apache proxy because i can’t export the nethserver directly and also because we have other services, so i’ve generated a certificate with let’s encrypt in this Apache proxy.
The problem is that when i try to edit a file the result is this error in network inspector:
bundle.js:41 WebSocket connection to 'wss://collaboratest.qubiarch.cloud/lool/https%3A%2F%2F192.168.20.8%2Fnextcloud%2Findex.php%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F153_oc4wmn37sjul%3Faccess_token%3DtNlIO1HLphKPOjoJr54qfyyM3Hq3Bqbx%26access_token_ttl%3D0%26permission%3Dedit/ws?WOPISrc=https%3A%2F%2F192.168.20.8%2Fnextcloud%2Findex.php%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F153_oc4wmn37sjul&compat=/ws' failed: Error during WebSocket handshake: Unexpected response code: 404 connect @ bundle.js:41 loadDocument @ bundle.js:42 _activate @ bundle.js:42 _onGotFocus @ bundle.js:43 handler @ bundle.js:49 focus @ bundle.js:47 focus @ bundle.js:42 _activate @ bundle.js:42 _onSocketClose @ bundle.js:41
this is the certificate in the apache proxy
<IfModule mod_ssl.c> <VirtualHost *:443> ServerAdmin #################à ServerName collaboratest.#####.cloud ServerAlias collaboratest.#####.cloud #DocumentRoot /var/www SSLCertificateFile /etc/letsencrypt/live/collaboratest.#####.cloud/fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/collaboratest.#####.cloud/privkey.pem Include /etc/letsencrypt/options-ssl-apache.conf ProxyPreserveHost On ProxyRequests On LogLevel warn SSLProxyEngine on SSLProxyVerify none SSLProxyCheckPeerCN off SSLProxyCheckPeerName off SSLProxyCheckPeerExpire off # <Proxy *> # Order deny,allow # Allow from all # </Proxy> ProxyPass / https://collaboratest.#####.cloud/ ProxyPassReverse / https://collaboratest.#####.cloud/ CustomLog /var/log/apache2/collaboratest.#####.cloud combined </VirtualHost> </IfModule>
this is the zz_collabora.conf
<VirtualHost *:443> ServerName collaboratest.#####.cloud SSLEngine on # Encoded slashes need to be allowed AllowEncodedSlashes NoDecode # keep the host ProxyPreserveHost On # static html, js, images, etc. served from loolwsd # loleaflet is the client part of LibreOffice Online ProxyPass /loleaflet http://127.0.0.1:9980/loleaflet retry=0 ProxyPassReverse /loleaflet http://127.0.0.1:9980/loleaflet # WOPI discovery URL ProxyPass /hosting/discovery http://127.0.0.1:9980/hosting/discovery retry=0 ProxyPassReverse /hosting/discovery http://127.0.0.1:9980/hosting/discovery # Main websocket ProxyPassMatch "/lool/(.*)/ws$" ws://127.0.0.1:9980/lool/$1/ws nocanon # Admin Console websocket ProxyPass /lool/adminws ws://127.0.0.1:9980/lool/adminws # Download as, Fullscreen presentation and Image upload operations ProxyPass /lool http://127.0.0.1:9980/lool ProxyPassReverse /lool http://127.0.0.1:9980/lool # Endpoint with information about availability of various features ProxyPass /hosting/capabilities http://127.0.0.1:9980/hosting/capabilities retry=0 ProxyPassReverse /hosting/capabilities http://127.0.0.1:9980/hosting/capabilities </VirtualHost>
and this is the loolwsd.conf
# keep the host
# Capabilities
# Main websocket
Any suggestions?
thanks
