Collabora (code) + mattermost
Hello,
i am trying to integrate mattermost and Collabora.
it would be useful…
After installed all, installed plugin, i can open an xls file on mattermost with collabora but can not save it.
When i click save, close file, re-open it… Nothing changed. A bit sad.
Mattermost log say:
“app/session.go:89”,“msg”:“Error while creating session for user access token”,“error”:"createSessionForUserAccessToken: Invalid or missing token., resource: UserAccessToken
I used:
Mattermost and Collabora installed fresh from software centre.
Not important issue, thanks if anyone already solved this problem.
Just for completeness, the issue is also reported here:
Already seen this issue. I think this plugin Is not much active, my issue could not be related to plugin.
I can confirm the issue. I tried changing permissions for the document files without success.
