On the Web Proxy & Filter application, Parent proxy, safe ports and proxy port fields have no format validation.
I know that @mamengoni is working on it, stay tuned
you’re right, confirmed bug:
The bug is fixed and issue is verified: https://github.com/NethServer/dev/issues/5885
Thanks for the fix.
I don’t know if I messed up my test machine, but with the fixed package the Proxy port field cannot be left empty (default) anymore.
I’ve a doubt about Parent proxy. When using a hostname, it has to be a FQDN or it can also be a short hostname or “computer name” (like localhost, myupstreamproxy …)?
When using an IP it allowed to set a network address, broadcast address and 0.0.0.0 (I know an admin wouldn’t use those, but just thought of it to push the validators, not trying to be a PITA).
Yes, there was a missing condition. Fixed.
At the moment the validation is Validate::HOSTADDRESS
, like in NethGUI. We can discuss to change it
