Cockpit OATH input field cursor auto focus
NethServer Version: 7 latest
Module: cockpit
Hey all,
When 2FA is enabled, the cockpit login screen has no automatic focus on the input field for the challenge. Instead, one must first click the input field before a code can be entered. Can this be changed to automatic cursor focus on that input field pls?
Now I have my cell in 1 hand and the typing the code with my other hand, and find out, after typing the code, that I had to click the input field first…
It was fixed upstream long ago (easy fix) but not ported to the packaged version of cockpit rpm for CentOS/RHEL7.
Great catch!, bummer tho.
Thanks for the deep dive.
