Hi, as I just told you I’m a newby with centos and nethserver internals, so be patien with me. I probably broken something with cockpit because when I try to log in i get: The cockpit package is not installed.
I see login page but after login and pass I get “not installed”
systemctl status -l cockpit.socket
● cockpit.socket - Cockpit Web Service Socket
Loaded: loaded (/usr/lib/systemd/system/cockpit.socket; enabled; vendor preset: disabled)
Active: active (listening) since Tue 2020-03-17 08:12:55 CET; 24h ago
Docs: man:cockpit-ws(8)
Listen: [::]:9090 (Stream)
Mar 17 08:12:55 box01.v20.it systemd[1]: Starting Cockpit Web Service Socket.
Mar 17 08:12:55 box01.v20.it systemd[1]: Listening on Cockpit Web Service Socket.
systemctl status -l cockpit.service
● cockpit.service - Cockpit Web Service
Loaded: loaded (/usr/lib/systemd/system/cockpit.service; static; vendor preset: disabled)
Active: inactive (dead) since Tue 2020-03-17 18:02:39 CET; 15h ago
Main PID: 24158 (code=exited, status=0/SUCCESS)
Mar 17 18:01:09 box01.v20.it systemd[1]: Starting Cockpit Web Service…
Mar 17 18:01:09 box01.v20.it remotectl[24156]: /usr/bin/chcon: can’t apply partial context to unlabeled file ‘/etc/cockpit/ws-certs.d/99-nethserver.cert’
Mar 17 18:01:09 box01.v20.it remotectl[24156]: remotectl: couldn’t change SELinux type context ‘etc_t’ for certificate: /etc/cockpit/ws-certs.d/99-nethserver.cert: Child process exited with code 1
Mar 17 18:01:09 box01.v20.it systemd[1]: Started Cockpit Web Service.
Mar 17 18:01:09 box01.v20.it cockpit-ws[24158]: Using certificate: /etc/cockpit/ws-certs.d/99-nethserver.cert
Mar 17 18:01:10 box01.v20.it cockpit-ws[24158]: couldn’t read from connection: Peer sent fatal TLS alert: Certificate is bad
Mar 17 18:01:17 box01.v20.it cockpit-session[24690]: pam_ssh_add: Failed adding some keys
Mar 17 18:01:17 box01.v20.it cockpit-ws[24158]: cockpit-bridge: error while loading shared libraries: libpolkit-agent-1.so.0: cannot open shared object file: No such file or directory
