please test and break it. Due to cockpit I cannot plug my code inside the nethserver-samba, so you have to create a shared folders first inside nethserver-samba panel, then go to nethserver-nfs, the NfsStatus of the sharedfolder is set to disabled by default .
check your export are well at : cat /etc/exports
check the upgrade from the former server-manager
@michelandre I stop the code for a while and I go to our studies
IF i mounted an additional EXT storage onto a serve with ENthserver, can i map nextcloud to store data onto that volume instead of the main volume, and how?
The account provider is a Debian AD Controller which the NS file server is joined to.
All users belong to the AD and every computer is joined to the AD.
So, everybody has his kerberos keytab. Why is “sec=krb5” not implemented in Nethserver NFS? Why is no "share 192.168.x.x/24(rw, sync,…) possible in the GUI? The LAN can only be set “ro” and clients with write permissions have to be listed one by one. That is annoying.
Meanwhile we have only one Windows PC left as “fallback” system. All other computers run Linux. NFS ist much more interesting for us than CIFS.
yes security is often something annoying I agree. I am kidding
NFS is based on IP for authorization, Sure that I could make an option in the UI, but it is not a good way to allow a full network. For this I think you could do a custom template yourself
someone asked for it 2 or three years ago, I think you can find some inputs on this forum, but nobody more. So it is not really a priority even if I understand the real improvement. If you have some hints or a howto, if you can get something workable and willing to help the development, then please ring the bell.
