WIP, still works to make happen
works : {
"translations":"done",
"validations":"done",
"domains page":"done",
"settings":"done",
"about":"done",
"logs":"done"
works : {
"settings":"done",
"about":"done",
"logs":"done"
I would like some inputs relative to the cockpit menu
yum install http://mirror.de-labrusse.fr/NethDev/awstats/nethserver-awstats-1.0.1-1.ns7.sdl.noarch.rpm
thank in advance
Hi stephdl,
happy new year for you and your family.
I installed it. It looks good to me.
Regards…
Uwe
Thank you @Stephdl, installed and working without issue.
installed on aarch64, and all seems to work. i’m not a heavy user of awstat, but all the config i need (and more) are present in the menu
tnx
some notes:
tk, maybe it makes sense to add localhosts as default
[root@ns7loc9 ~]# grep -srni 'skiphost' /etc/
/etc/awstats/awstats.plop.vhost.conf:470:SkipHosts="127.0.0.1"
127.0.0.1 is not enough, I saw it is set per default ?
released
Good Morning, i have installed awstats this morning, at installation everything went well but i did not see an entry for the configuration. not in the old servermanager and also not in the cockpit ui. is there something i miss?
Did you install nethserver-awstats ?
yes, from this threat here.
What are the version please, normally except for testing, all versions must be installed from my repo, check the wiki
yum install http://mirror.de-labrusse.fr/NethDev/awstats/nethserver-awstats-1.0.1-1.ns7.sdl.noarch.rpm this one
Check the wiki and install from my repo please
okay, will check it out.
worked, thank you @stephdl
