short answer but yes you can move app to another node
no there is nothing, behind it is podman and systemd
docker is hell and I am not sure that podman and docker could live together, anyway, just do an alias docker to podman and it is all…not completely true
However if the question is, can I take a container from dockerhub an run it myself with podman the answer is yes, this is what we do
external backup yes, external storage mounted to the node, I think it is a bit experimental but it should work
Thanks very much Steph
In the meantime I’ve cleared my head about PODMAN Thanks
Request ,
so I only do any “vmotion” from the command line (BASH),
if I have an APP/Container MailServer with a size of 1Tb on one node, on the second node I will have the same APP with the same size, how does data synchronization take place, RSYNC or other?
Are the Buildah and Skopeo tools used?
Is Skoepo the one for moving containers?
Thanks bye
no synchronisation, you can move the app with a rsync container, the module is cloned first then once completed it is removed from the previous node. But thinking on it we could probably do a poor HA by copying the data on time based
yes buildah is used to build our module image
no rsync is used to move the files and the volumes
