NethServer Version: NS8 Beta1 on Debian 11
I installed the cluster leader on 192.168.3.209.
The browser cannot connect to https://192.168.3.209/cluster-admin/
I had no such problem evaluating the Alpha.
Sincerely, Marko
Sincerely, Marko
Did the NS8 installation finish correctly? During testing, one time the installation was interrupted due to a not working download.
Is traefik listening on https port?
root@node1:~# ss -ltp | grep https
LISTEN 0 4096 *:https *:* users:(("traefik",pid=827,fd=9))
I think so.
Storing signatures
19d93e981c33f9f41bae92b525644f133cfdd431fbdb8cec171d43183fda455b
<7>extract-ui Package traefik ¡ GitHub
Extracting container filesystem ui to /var/lib/nethserver/cluster/ui/apps/traefik1
ui/index.html
ebc2fc066f7e1013d31cd525a02760451dc08d427b03e58e68535b8aa2a6d6a1
{âmodule_idâ: âtraefik1â, âimage_nameâ: âtraefikâ, âimage_urlâ: âPackage traefik ¡ GitHubâ}
Setting default admin password:
True
NethServer 8 Core
Finish the cluster configuration by running one of the following procedures.
A. To join this node to an already existing cluster run:
âŚ
My last action was to create the cluster leader, finished with the joining information for the admin user.
âŚno out put
Did you do it on command line or in the web UI?
I think it wasnât possible in the alpha version but now you can go to https://<ip>/cluster-admin immediately after NS8 installation to create the cluster.
It was.
The trailing slash is important: https://<ip>/cluster-admin/
Here it worked without it, itâs appended automatically.
Hmmm, perhaps thatâs changed. When I first tried NS8, it wouldnât work without it.
I created the cluster leader within the console.
I did and just forgot to post it here.
Addional I checked the web serverâŚ
systemctl status apache2
â apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2023-05-15 07:36:37 CEST; 8min ago
Docs: Apache HTTP Server Version 2.4 Documentation - Apache HTTP Server Version 2.4
Process: 418 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/SUCCESS)
Main PID: 538 (apache2)
Tasks: 55 (limit: 9492)
Memory: 11.6M
CPU: 187ms
CGroup: /system.slice/apache2.service
ââ538 /usr/sbin/apache2 -k start
ââ539 /usr/sbin/apache2 -k start
ââ540 /usr/sbin/apache2 -k start
cat /etc/apache2/mods-enabled/status.conf
# Allow server status reports generated by mod_status,
# with the URL of http://servername/server-status
# Uncomment and change the "192.0.2.0/24" to allow access from other hosts.
<Location /server-status>
SetHandler server-status
Require local
#Require ip 192.0.2.0/24
</Location>
# Keep track of extended status information for each request
ExtendedStatus On
# Determine if mod_status displays the first 63 characters of a request or
# the last 63, assuming the request itself is greater than 63 chars.
# Default: Off
#SeeRequestTail On
<IfModule mod_proxy.c>
# Show Proxy LoadBalancer status in mod_status
ProxyStatus On
</IfModule>
#vim: syntax=apache ts=4 sw=4 sts=4 sr noet
ps -eo comm,etime,user | grep apache2
apache2 12:42 root
apache2 12:42 www-data
That seems very likely to be a problem; my installation of NS8 doesnât have Apache installed at all. Where did it come from?
Indeed.
Apache should not be installed because traefik must listen on port 80 and 443.
Ok! Itâs more clear now.
I installed Webserver together with the basic Debian installation.
I will repeat the installation.
I do think this points to a shortcoming in the installer script, though, in that itâs not very good at detecting and either fixing, or aborting on, errors. Trying to run it on a system that has Apache running, for example (assuming itâs listening on the default ports), should result in an obvious hard failure. But it doesnât; the installer script behaves as though the installation was successful.
Thatâs certainly your problem. Minimal install is all thatâs needed.
Added a new card for the check.
Reinstallation works fine.
Thank you.
Thank you for the new test Marko!
