this is a script to automate the creation of an A record (tested and working) with cloud flare
cloudflareA.sh
#!/usr/bin/env bash
echo -e
echo "What is the email address associated with your cloudflare account?"
echo -e
read -r email
sleep 0.2s
echo -e
echo "What is the Global API Key associated with your cloudflare account?"
echo -e
read -r key
echo -e
echo "What is the name of the A record you wish to make?"
echo -e
read -r A
echo -e
echo "What is IP address for $A?"
echo -e
read -r IP
read -r -p "Would you like to set this as Proxied? [Y/n] " input
case $input in
[yY][eE][sS]|[yY])
curl -X GET "https://api.cloudflare.com/client/v4/zones" \
-H "X-Auth-Email: $email" \
-H "X-Auth-Key: $key" \
-H "Content-Type: application/json" \
| python -c $'import sys,json\ndata=json.loads(sys.stdin.read())\nif data["success"]:\n\tfor dict in data["result"]:print("Zone ID: " + dict["id"])\nelse:print("ERROR(" + str(data["errors"][0]["code"]) + "): " + data["errors"][0]["message"])' > zoneid.txt
curl -X POST "https://api.cloudflare.com/client/v4/zones/$(sed 's/Zone ID: //' zoneid.txt)/dns_records/" \
--data '{"type":"'"A"'","name":"'"$A"'","content":"'"$IP"'","proxied":'"true"',"ttl":'"1"'}' \
| python -m json.tool;
[nN][oO]|[nN])
--data '{"type":"'"A"'","name":"'"$A"'","content":"'"$IP"'","proxied":'"false"',"ttl":'"1"'}' \
echo "Invalid input..."
exit 1
esac
this is a script to automate the creation of a CNAME record (tested and working) with cloud flare
cloudflareCNAME.sh
#!/usr/bin/env bash
echo -e
echo -e
read -r email
sleep 0.2s
echo -e
echo -e
read -r key
echo -e
echo "What is the name of the CNAME record you wish to make?"
echo -e
read -r CNAME
echo -e
echo "What is The A record $CNAME will point to?"
echo -e
read -r A
case $input in
[yY][eE][sS]|[yY])
--data '{"type":"'"CNAME"'","name":"'"$CNAME"'","content":"'"$A"'","proxied":'"true"',"ttl":'"1"'}' \
[nN][oO]|[nN])
--data '{"type":"'"CNAME"'","name":"'"$CNAME"'","content":"'"$A"'","proxied":'"false"',"ttl":'"1"'}' \
exit 1
esac
this is a script to automate the creation of an MX record (tested and working) with cloud flare
cloudflareMX.sh
#!/usr/bin/env bash
echo -e
echo -e
read -r email
sleep 0.2s
echo -e
echo -e
read -r key
echo -e
echo "What is the host to be (use @ for root domain)?"
echo -e
read -r domain
echo -e
echo "What is the FQDN that this MX record will point to?"
echo -e
read -r MXDomain
echo -e
echo "What priority do you want to set?"
echo -e
read -r priority
--data '{"type":"'"MX"'","name":"'"$domain"'","content":"'"$MXDomain"'","priority":'"$priority"',"ttl":'"1"'}' \
this is a script to automate the creation of an TXT record (tested and working) with cloud flare
cloudflareTXT.sh
#!/usr/bin/env bash
echo -e
echo -e
read -r email
sleep 0.2s
echo -e
echo -e
read -r key
echo -e
echo -e
read -r domain
echo -e
echo "What content is to be included in the TXT record?"
echo -e
read -r content
--data '{"type":"'"TXT"'","name":"'"$domain"'","content":"'"$content"'","ttl":'"1"'}' \
this is a script to automate the creation of a DMARC record (tested and working) with cloud flare
cloudflareDMARC.sh
#!/usr/bin/env bash
echo -e
echo -e
read -r email
sleep 0.2s
echo -e
echo -e
read -r key
--data '{"type":"'"TXT"'","name":"'"_dmarc"'","content":"'"v=DMARC1; p=quarantine; rua=mailto:autoreply@dmarctest.org"'","ttl":'"1"'}' \
this is a script to automate the creation of a PTR record (tested and working) with cloud flare
cloudflarePTR.sh
#!/usr/bin/env bash
echo -e
echo -e
read -r email
sleep 0.2s
echo -e
echo -e
read -r key
echo -e
echo "What is the IP of the Reverse IP record?"
echo -e
read -r IP
echo -e
echo "What is FQDN that this record will be pointing to?"
echo -e
read -r FQDN
--data '{"type":"'"PTR"'","name":"'"$IP"'","content":"'"$FQDN"'","ttl":'"1"'}' \
