Hello after 20 years with smeserver we decided to start with your great tool. Thanks for your superb work !
My actual problem is to connect my server to my nordnet provider and use our dedicated vpn ip
i try during this last days, open the firewall…but client dont want to start, openvpn server start without problem.
Is someone could help me to start client side?
wich part of the certificat need to be use?
regards
Nord vpn .conf is:
client
dev tun
proto udp
remote 185.128.25.93 1194
resolv-retry infinite
remote-random
nobind
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
ping 15
ping-restart 0
ping-timer-rem
reneg-sec 0
explicit-exit-notify 3
remote-cert-tls server
#mute 10000
auth-user-pass
comp-lzo
verb 3
pull
fast-io
cipher AES-256-CBC
auth SHA512
<ca>
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
</ca>
key-direction 1
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
9bafe03c3395f4c395fa750ba5516836
a5bafbda3aef472ca56c8a9736c648f6
a077b53dedcf560d0d178dd6c565cfff
c89284f465d76088aa5b54a158ee3b43
aec6586497eb78c653a86e8b2367bee5
2915629301427e85b16800f3cc73ee13
4a03d7c5cd3817319f18a7a1e6176016
d76c4b3553ee4828f7653bc428c7ddc1
-----END OpenVPN Static key V1-----
</tls-auth>
NethServer Version: 7
Module: openvpn
