Hi, was trying to update marketplace and apps but could not progress until I clear cache. I cleared it but still getting same error message. Does anyone have a fix? Thanks.
Welcome in our big tribe
What version of NS are you trying to deploy?
Hi, its as follows:
System version
NethServer release 6.7 (final)
Kernel release
2.6.32-573.22.1.el6.x86_64
My guess is that you hit this error which flashes on the screen first and is then replaced by the one you see.
Cheers.
I did a rebuild (just for the heck of it) and installed market apps one at a time. It is slow going but seems the Clear YUM Cache error message went away. Cheers
You can always clean yum cache from command line :
yum clean all
I think i have the same error with the latest batch of updates. I did a yum clean all from command line, and yum update. There are several errors flagged in the output of running the yum update command. Here is the output:
login as: root
root@10.20.30.1’s password:
Last login: Sat Apr 2 16:07:10 2016 from 10.20.30.250
************ Welcome to NethServer ************
This is a NethServer installation.
Before editing configuration files, be aware
of the automatic events and templates system.
http://docs.nethserver.org
[root@tempest ~]# yum clean all
Loaded plugins: changelog, fastestmirror, nethserver_events, presto
Cleaning repos: centos-base centos-updates nethserver-base nethserver-updates
Cleaning up Everything
Cleaning up list of fastest mirrors
0 delta-package files removed, by presto
[root@tempest ~]# yum update all
Setting up Update Process
- centos-base: repos.lax.quadranet.com
- centos-updates: centos-distro.cavecreek.net
- nethserver-base: mirror.nethserver.org
- nethserver-updates: mirror.nethserver.org
No Match for argument: all
No package all available.
No Packages marked for Update
Loading mirror speeds from cached hostfile - centos-base: repos.lax.quadranet.com
Resolving Dependencies
–> Running transaction check
—> Package libldb.x86_64 0:1.1.13-3.el6_7.1 will be updated
—> Package libldb.x86_64 0:1.1.25-2.el6_7 will be an update
—> Package libtalloc.x86_64 0:2.0.7-2.el6 will be updated
—> Package libtalloc.x86_64 0:2.1.5-1.el6_7 will be an update
—> Package libtdb.x86_64 0:1.2.10-1.el6 will be updated
—> Package libtdb.x86_64 0:1.3.8-1.el6_7 will be an update
—> Package libtevent.x86_64 0:0.9.18-3.el6 will be updated
—> Package libtevent.x86_64 0:0.9.26-2.el6_7 will be an update
—> Package pytalloc.x86_64 0:2.0.7-2.el6 will be obsoleted
—> Package pytalloc.x86_64 0:2.1.5-1.el6_7 will be obsoleting
—> Package samba.x86_64 0:3.6.23-25.el6_7 will be updated
—> Package samba.x86_64 0:3.6.23-30.el6_7 will be an update
—> Package samba-client.x86_64 0:3.6.23-25.el6_7 will be updated
—> Package samba-client.x86_64 0:3.6.23-30.el6_7 will be an update
—> Package samba-common.x86_64 0:3.6.23-25.el6_7 will be updated
—> Package samba-common.x86_64 0:3.6.23-30.el6_7 will be an update
—> Package samba-winbind.x86_64 0:3.6.23-25.el6_7 will be updated
—> Package samba-winbind.x86_64 0:3.6.23-30.el6_7 will be an update
—> Package samba-winbind-clients.x86_64 0:3.6.23-25.el6_7 will be updated
—> Package samba-winbind-clients.x86_64 0:3.6.23-30.el6_7 will be an update
—> Package samba4-libs.x86_64 0:4.0.0-68.el6_7.rc4 will be updated
–> Processing Dependency: libcli-ldap.so()(64bit) for package: winexe-1.1-1.git .0.9d83c1e.el6.x86_64
–> Processing Dependency: libcli-ldap.so(SAMBA_4.0.0RC4)(64bit) for package: wi nexe-1.1-1.git.0.9d83c1e.el6.x86_64
–> Processing Dependency: libdcerpc-samba.so()(64bit) for package: winexe-1.1-1 .git.0.9d83c1e.el6.x86_64
–> Processing Dependency: libdcerpc-samba.so(SAMBA_4.0.0RC4)(64bit) for package : winexe-1.1-1.git.0.9d83c1e.el6.x86_64
–> Processing Dependency: liberrors.so()(64bit) for package: winexe-1.1-1.git.0 .9d83c1e.el6.x86_64
–> Processing Dependency: liberrors.so(SAMBA_4.0.0RC4)(64bit) for package: wine xe-1.1-1.git.0.9d83c1e.el6.x86_64
—> Package samba4-libs.x86_64 0:4.2.10-6.el6_7 will be an update
—> Package selinux-policy.noarch 0:3.7.19-279.el6_7.8 will be updated
—> Package selinux-policy.noarch 0:3.7.19-279.el6_7.9 will be an update
—> Package selinux-policy-targeted.noarch 0:3.7.19-279.el6_7.8 will be updated
—> Package selinux-policy-targeted.noarch 0:3.7.19-279.el6_7.9 will be an upda te
—> Package tdb-tools.x86_64 0:1.2.10-1.el6 will be updated
—> Package tdb-tools.x86_64 0:1.3.8-1.el6_7 will be an update
–> Finished Dependency Resolution
Error: Package: winexe-1.1-1.git.0.9d83c1e.el6.x86_64 (@nethserver-base)
Requires: libcli-ldap.so(SAMBA_4.0.0RC4)(64bit)
Removing: samba4-libs-4.0.0-68.el6_7.rc4.x86_64 (@centos-updates)
Updated By: samba4-libs-4.2.10-6.el6_7.x86_64 (centos-updates)
Not found
Available: samba4-libs-4.0.0-66.el6_6.rc4.x86_64 (centos-base)
Available: samba4-libs-4.0.0-67.el6_7.rc4.x86_64 (centos-updates)
Requires: liberrors.so(SAMBA_4.0.0RC4)(64bit)
Not found
Requires: libcli-ldap.so()(64bit)
Not found
Requires: liberrors.so()(64bit)
Not found
Requires: libdcerpc-samba.so()(64bit)
Not found
Requires: libdcerpc-samba.so(SAMBA_4.0.0RC4)(64bit)
Not found
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
it is the same issue as it was discussed before.
Please procced with this and back to us with the results.
Nas, WOW you are quick To confirm, you want me to do this:
yum localinstall http://packages.nethesis.it/nethserver/6.7/testing/x86_64/Packages/winexe-1.01-1.x86_64.rpm
yum install nethserver-adagios
Correct?
I noticed this clear cache issue comes up and won’t go away when I tried to add “Monitoring and inventorying” from the marketplace. Other times, the clear cache notification goes away after I clear cache and reboot.
Later…yep that is the problem at least on my machine.
@harry please proceed !
@dreamerman as you may reed the main misconfigure is leaded by adagios package.
Thus please remove it or please apply the workaroud from the @dev_team .
[> root@server ~]# yum localinstall http://packages.nethesis.it/nethserver/6.7/testing/x86_64/Packages/winexe-1.01-1.x86_64.rpm
Setting up Local Package Process
winexe-1.01-1.x86_64.rpm | 1.9 MB 00:01
Examining /var/tmp/yum-root-pGYEiC/winexe-1.01-1.x86_64.rpm: winexe-1.01-1.x86_64
/var/tmp/yum-root-pGYEiC/winexe-1.01-1.x86_64.rpm: does not update installed package.
Nothing to do
[root@server ~]#
and now?
Instructions are valid only for new installations.
In your case:
rpm -e --nodeps winexe
yum update --exclude=winexe
Thanks, it worked.
thanks, it’s work
but after this method i have this:
Carlo,
Thanks for the nudge.
I ran the two commands. Output follows. In trying to update software, I get:
Resolving RPM dependencies
The install/update may have failed due to metadata caching issues. Please clean the cache by clicking the button below and retry the install/update operation.
Clear Yum Cache doesn’t help.
[root@tempest ~]# yum localinstall http://packages.nethesis.it/nethserver/6.7/testing/x86_64/Packages/winexe-1.01-1.x86_64.rpm
winexe-1.01-1.x86_64.rpm | 1.9 MB 00:03
Examining /var/tmp/yum-root-JXkt9I/winexe-1.01-1.x86_64.rpm: winexe-1.01-1.x86_64
/var/tmp/yum-root-JXkt9I/winexe-1.01-1.x86_64.rpm: does not update installed package.
Nothing to do
Nothing to do
[root@tempest ~]#
Harry
good!!!
now all my client have problem with trust when login
Ignore the message until Red Hat fixes the bug on samba packages
Giacomo, thank you (I didn’t see your earlier post until after I tried the first suggested procedure.
I got the same result gecco posted, with the remaining error message about winexe.
