Hi everyone,
Is there a function somewhere that is recommended to use to clean logs in /var/log which is getting quite big? Otherwise this will take some time to remove manually.
Thank
Hi everyone,
Thank
there are a few tweaks to slim down the logs a bit (in System > Settings) :
The one year retention (52 weeks) is for service purposes;
Meaning if you have an subscription and open a ticket nethserver may not be able to help you to the full extent if one alters the settings here .
Thanks for the help @mark_nl
