NethServer Version: 7.9
Antivirus
ClamScan: Engine version: 0.103.7
Hell all,
within my logs I found:
----------- SCAN SUMMARY -----------
Known viruses: 0
Scanned directories: 52687
Scanned files: 275278
Infected files: 0
Data scanned: 60239.48 MB
Data read: 120217.95 MB (ratio 0.50:1)
Time: 969.439 sec (16 m 9 s)
Start Date: 2022:08:13 03:35:01
End Date: 2022:08:13 03:51:11
My first view was going to Settings:
If I update the Database manually after them:
Perhaps…: “You are on cool-down until after: 2022-08-13 11:00:40”
Within Antivirus, I activated official signatures.
LOG:
Aug 13 06:31:12 Nethserver.###.de systemd[1]: Starting clamd scanner (rspamd) daemon…
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Received 0 file descriptor(s) from systemd.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: clamd daemon 0.103.7 (OS: linux-gnu, ARCH: x86_64, CPU: x86_64)
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Log file size limited to 1048576 bytes.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Reading databases from /var/lib/clamav
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Not loading PUA signatures.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Bytecode: Security mode set to “TrustSigned”.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Loaded 1 signatures.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: LOCAL: Unix socket file /var/run/clamd@rspamd/clamav
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: LOCAL: Setting connection queue length to 200
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: Global time limit set to 120000 milliseconds.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: Global size limit set to 104857600 bytes.
Aug 13 06:31:12 Nethserver.###.declamd[9596]: Limits: File size limit set to 26214400 bytes.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: Recursion level limit set to 17.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: Files limit set to 10000.
Aug 13 06:31:12 Nethserver.###.de systemd[1]: Started clamd scanner (rspamd) daemon.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: MaxEmbeddedPE limit set to 10485760 bytes.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: MaxHTMLNormalize limit set to 10485760 bytes.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: MaxHTMLNoTags limit set to 2097152 bytes.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: MaxScriptNormalize limit set to 5242880 bytes.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: MaxZipTypeRcg limit set to 1048576 bytes.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: MaxPartitions limit set to 50.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: MaxIconsPE limit set to 100.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: MaxRecHWP3 limit set to 16.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: PCREMatchLimit limit set to 100000.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: PCRERecMatchLimit limit set to 2000.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Limits: PCREMaxFileSize limit set to 26214400.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Archive support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: AlertExceedsMax heuristic detection disabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Heuristic alerts enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Portable Executable support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: ELF support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Mail files support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: OLE2 support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: PDF support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: SWF support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: HTML support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: XMLDOCS support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: HWP3 support enabled.
Aug 13 06:31:12 Nethserver.###.de clamd[9596]: Self checking every 600 seconds.
Aug 13 06:41:12 Nethserver.###.de clamd[9596]: SelfCheck: Database status OK.
What is happened there? Why “Known viruses: 0”?
best regards, MArko
