Perakes
(Perakes)
March 1, 2020, 4:01pm
1
Hello everyone,
I´m receiving around every 6 hours the following email from my nethserver:
Von: (Cron Daemon) nethserver@xxx
Gesendet: Sonntag, 1. März 2020 16:23
An: root@xxx
Betreff: Cron root@nethserver [ -x /usr/sbin/clamav-unofficial-sigs.sh ] && /bin/bash /usr/sbin/clamav-unofficial-sigs.sh
xargs: WARNING: a NUL character occurred in the input. It cannot be passed through in the argument list. Did you mean to use the --null option?
Netserver is 7.7.1908 with all updates installed. AFIAK I havn´t done any modifications beside:
yum --enablerepo=epel-testing update clamav-unofficial-sigs
Any suggestions on how to solve this problem?
Thanks / Perakes
mrmarkuz
(Markus Neuberger)
March 3, 2020, 3:11pm
2
Hi and welcome to Nethserver Community,
I updated clamav-unofficial-sigs from epel-testing but couldn’t reproduce the issue.
Do you get more detailed error output when you run it directly:
Are there errors in the logs /var/log/messages or /var/log/clamav-unofficial-sigs/clamav-unofficial-sigs.log ?
If there’s an error in the script you could try to reinstall:
yum reinstall clamav-unofficial-sigs --enablerepo=epel-testing
or downgrade from epel-testing package:
yum downgrade clamav-unofficial-sigs
Perakes
(Perakes)
March 3, 2020, 5:28pm
3
Hello Markus,
thank you for your reply, I think I found the problem. The logs didn´t show any significant error beside:
No LinuxMalwareDetect database file updates found
rfxn.com was blocked by my firewall/pfblockerNG. I whitelisted rfxn.com and since this there are no more emails and the logs show that the database files get updated.
Sorry I´m not really a Linux guy: If I downgrade via
will it go backwards to epel repo or can I leave the epel-testing repo for clamav-unoffical-sigs
Thank you for your help
Perakes
mrmarkuz
(Markus Neuberger)
March 3, 2020, 5:36pm
4
You’re welcome.
yum downgrade clamav-unofficial-sigs downgrades to epel version, not epel-testing.
