ClamAv+Https scanning feature?
Hey everyone ! Im using the nethserver proxy
Manual mode ; with block all http and https ports.
Also Im using web content filter with Antivirus enabled.
For example Ive used forbid social networking.
It says page not availble ( for example https://facebook.com )
No red page with forbidden like when you go to http social networking.
However the antivirus seems to be working only with http but not with https …
Is there such feature or not?
Thank you.
Nevermind. Ive figured it out that using transparent with ssl works .
I have a stupid question with my setup.
For example DHCP and DNS server is Active directory 2012 windows. 192.168.0.13
Default gateway is 192.168.0.14
Proxyserver is nethserver. 192.168.0.12
What are my settings ?
I figured I need to point Windows machine to default gateway to Proxyserver ( 192.168.0.12 )
Do I have to reserve IP address in active directory for that… ? Confused
In my opinion, a ssl connection like https is a connection directly to the internet domain from client. If you wanna check the transfer between client and internet you have to use a ssl proxy. But basicly ssl use certificates. If the certificate is valid then you can trust. :wink: Just that is the problem.
By the way - try to use “transparent mode”
For the Firewall
  • Custom categories
  • Custom categories can be used inside the Filter tab.
    – A list of custom domains, one per line.
