Depending on your Internet connection, clamav-db RPM could be a “big” (86MB): could it be a proxy timeout or any other network issue?
Does anyone have the same problem?
I’m having issues installation hangs on yum clamav install, did it happen to any of you?
In fact it hangs on
Download
clamav-db-0.98.4-1.el6.x86_64.rpm
clam-av and initernet… You going to need a super fast internet and slow on Clam on processing!
Cheers,
Horace
adsl speed show 2.5mbps, other packages download ok, its just clamav that fails, any ideas?
As shown bellow speed is good, but at a certain point starts dropping and fials with
Trying other mirror.
http://mirror.nethesis.it/nethserver/6.6/base/x86_64/Packages/clamav- .el6.x86_64.rpm: [Errno 14] PYCURL ERROR 6 - "Couldn’t resolve host ’ esis.it’"
clamav-db-0.98.4-1.el6.x8 50% [=======- ] 269 kB/s | 43 MB clamav-db-0.98.4-1.el6.x8 50% [=======- ] 268 kB/s | 44 MB clamav-db-0.98.4-1.el6.x86 51% [======== ] 272 kB/s | 44 MB 02:
http://mirror.nethserver.org/nethserver/6.6/base/x86_64/Packages/clamav-db-0.98.4-1.el6.x86_64.rpm: [Errno 12] Timeout on http://mirror.nethserver.org/nethserver/6.6/base/x86_64/Packages/clamav-db-0.98.4-1.el6.x86_64.rpm: (28, ‘Operation too slow. Less than 1 bytes/sec transfered the last 30 seconds’)
The issue may come that there are no mirror repositories for neth and for a huge rpm like this it is difficult to do a download during a lot of time…mainly I believe that you live in south america and the distance can make easily the issue.
For testing purpose you can download and install clamav and its dependencies from epel and after do a ‘yum update’
In other hand it is maybe time to ask about mirrors to the community.
Hello,
Mirror size?
Cheers,
Horace
actually around 1.1 tera
installed from epel repo with no problems.
Erratum sorry, the size is around 1.1 giga, thousand less
Finally i was able to install clamav after trying for nearly a week it
downloaded.
Good to know! problem resolved!
Ahh, 1.1 GiB is natta, can’t promise high speed but 10/20Mbps be good enough? Although, if most folks are in EU, there will be decent latency.
Regards,
Horace
Well standing on SourceForge stats the US are the gold medal for RC1 downloads I hope they’ll need updates too! So @lhprojects, your mirror will be popular I hope!
Same here…i can find place on aubrac-medical.fr https://geekeries.de-labrusse.fr/?page_id=2076
Beautiful! Do we need a mirror howto?
did you installed clamav from epel?
Wow! Fixed immediately. Great Job.
