Choosing the right tool for multi-language support
I like free hosted services like Transifex… Any idea?
Transifex is simple for the end user, maybe we need to setup a little bit of automation to import the code.
Anyone knows any other hosted service?
I like it, really. I used it for translate sogo years ago it’s very very easy and I assure you that in 10 minutes you can translate tens of words!
@giacomo can we estimate the efforts to setup a little bit of automation?
Maybe it is not a requirement to start with. Some automated GitHub/Transifex connectors exist, but I’m not sure we really need them. The Transifex client can fit our workflow as is, I think.
Like we talked about at the ‘mort subite’…it is a mandatory… No matter the way used
