Chinese Mini-PC With 4G and 6 NICS
@pike
I use a couple of HP MicroServers for my clients:
HP MicroServer Gen 8: Intel Celeron, or Xeon Quad Core CPUs, max RAM 16 GB.
CPU is not Hyperthreaded, shows up in Proxmox as 4 CPUs. 2 NICs.
HP MicroServer Gen 10: AMD Quad Core CPUs, max RAM 32 GB. No ILO / IPMI. CPU is a little underpowered. CPU is not Hyperthreaded, shows up in Proxmox as 4 CPUs. 2 NICs.
HP MicroServer Gen 10 Plus: Intel Quad Core CPU, max RAM 32 GB Official supplied, or 64 GB if you get your own. Optional ILO / IPMI. CPU is not Hyperthreaded, shows up in Proxmox as 4 CPUs. CPU can be replaced with a Intel 6 core with Hyperthreading, shows up in Proxmox as 12 Cores. This box is only half the size of the above two, but has the most options. 4 NICs.
I have a Gen8 at home, also running TrueNAS with a System-SSD and 2*4 TB WD Red Disks.
This has 16 GB RAM.
I also have a HP Microserver Gen 10 Plus, this is running as Proxmox.
I think @alefattorini should raise a new badge… OT Tamer, to whip the OTs before they come wild…
:rofl:
I know at least 3 servers of this kind with nethserver! :slight_smile:
I’d love to see what spectre-meltdown-checker would tell about that CPU/APU. Xeon Gold 5218 still vulnerable to CVE-2017-5715 with current kernel settins…
Time to reboot, dude, 3.10.0-1160.42.2 is out now :wink: (kernel version is quite longer than Itallian VAT number)
i think this supermicro can get the job done 5019D-4C-FN8TP | 1U | SuperServers | Products | Super Micro Computer, Inc.
amazon: https://www.amazon.com/Supermicro-SYS-5019D-4C-FN8TP-D-2133IT-Server-10GBase-T/dp/B08B3GCZVW
Senetic Supermicro SYS-5019D-4C-FN8TP now 25% off SuperServer 5019D-4C-FN8TP Intel SoC FCBGA2518
