I have tried the new configuration and I have only a LAN network defined.
The default nameserver is 8.8.8.8 but I want to change it to the local one.
I changed manually the config in the file:
/var/lib/nethserver/db/configuration
But there was a command to do that(don’t remember…)
And there should be a WEBUI option for that if I’m not wrong, Where?
