NethServer Version: 7.9.2009
Module: trusted networks
I have a web proxy with filtering, networks that have access are registered in trusted networks. After removing a network from trusted networks, access to the web proxy is not closed. How to make the changes apply and access is limited?
Hi Roman
You can try this command:
signal-event nethserver-squid-save
or simply reboot the server (Better, but not always possible)…
I have a problem if the network has not been added to the Internet, if adding and removing access to the network remains. Perhaps I am doing something wrong?
