Change storage path for shares
NethServer Version: NethServer 7.9.2009
Module: File Server
Do you know how to modify the storage path? I want my shared folders to be stored on another drive. Thank you.
Hi @John_Erik
And welcome to the Nethserver forum!
Easiest way is eg creating a symlink at /var/lib/nethserver/ibay/, pointing to your prepared disk. I’d suggest to use XFS, as NethServer also uses XFS by default.
You will need to manually move the data / files.
No templates for e-smith are needed.
I use mount points for these drives with fstab.
Hi @sternkrabbe
Actually, I just enlarge the disks using the slider in Proxmox… No modifications on the system…
None of my 30 clients use “native installs” on hardware for a long time now - the last one virtualized 7 years ago…
:slight_smile:
