For a better visibility about disabled/locked accounts, can you change the default color to red?
Which could be not different to color-blind people?
Or the possibility to customize the color
I wouldn’t change it.
The choice of a color must be consistent. IIUC red should be for dangers. The UI design reference is https://www.patternfly.org/v3/
