Operating System NethServer release 7.7.1908 (final)
I’m using LetsEncrypt certificates. I have not had any notification of certificate revokes, and up to today, 13 April, everything was fine. Today, I can access the three sites I’m running, as usual, on https.
However, if I try to browse to <IP_Address>:980, in Firefox or Chrome, I get notification of revoked certificates, and both browsers refuse to go further. Then it gets weird…I can ssh into the console no problem, and I can go to <IP_Address>:9090 and get a warning but I can proceed to the console by accepting the warning.
I thought the certs could be renewed by issuing “/usr/local/bin/certbot-auto --apache”. That completed fine, but didn’t make a change. I thought about a reboot at this point, but I’ve still got service and I don’t want to reboot and maybe loose what I have got…
Almost looks like your system isn’t serving the same certificate for the old server manager as it is for your web sites and for Cockpit, which would be very strange. You can start by comparing the output (from a *nix or Mac client machine) of openssl s_client -connect yourdomain.com:443 with openssl s_client -connect yourdomain.com:980. Those commands will give you the actual certificates your system is presenting on each port. You can visually look and see if they look the same, but it’d probably be easier to paste them into an online certificate decoder (e.g., Certificate Decoder - Decode certificates to view their contents). Or you can decide it yourself by running openssl x509 -in certificate.crt -text -noout, where certificate.crt is the contents of the cert saved to a text file.
Keep in mind that you’ll always get certificate errors if you’re using a trusted cert and browsing to an IP address, as the cert only covers FQDNs, not IP addresses.
Thanks for the quick response. I checked the certificates, they are as you suggest, different. They start with the same strings, but the last 340 characters differ. I am using the FQDN, not the IP addresses. The server and vHosts are behind NAT, but the same occurs either side of the NAT barrier.
I have a single certificate, valid for all three sites, set up as default
…though the certificate error that would give you is not that the cert is revoked.
My speculation at this point is that your cert is in fact revoked, but that fact isn’t obvious on your main site because revocation is broken. You can test this using the ssllabs.com tester (SSL Server Test (Powered by Qualys SSL Labs)), which does check revocation status. If I’m correct, the reason for the difference is that the server manager uses OCSP stapling, which attaches a certificate of the current revocation status to server’s certificate. However, the main Apache instance doesn’t do this, and apparently Cockpit doesn’t either.
If I’m correct that your cert is revoked, the fix is simple: certbot renew --force-renewal.
Could not choose appropriate plugin: The requested apache plugin does not appear to be installed
Attempting to renew cert (<FQDN#1 obscured>) from /etc/letsencrypt/renewal/<FQDN#1 obscured>.conf produced an unexpected error: The requested apache plugin does not appear to be installed. Skipping.
Attempting to renew cert (<FQDN#2 obscured>) from /etc/letsencrypt/renewal/<FQDN#2 obscured>.conf produced an unexpected error: The requested apache plugin does not appear to be installed. Skipping.
All renewal attempts failed. The following certs could not be renewed:
/etc/letsencrypt/live/<FQDN#1 obscured>/fullchain.pem (failure)
/etc/letsencrypt/live/<FQDN#2 obscured>/fullchain.pem (failure)
2 renew failure(s), 0 parse failure(s)
So it would appear that apache plugin does not appear to be installed…but what apache plugin?
Did you first confirm that your cert was actually revoked using the ssllabs test?
That shouldn’t be happening, unless your previous attempt at running certbot apache confused it. Try re-requesting the cert through the (Cockpit) server manager–that should reset the options.
