Certificate is not trusted
Good evening,
Since IOS 17, the option “always trust the certificate” has been removed.
How can I solve this problem to reconnect to my email account.
Best regards
Hi @Amort_Gottfried
Simple, get a LetsEncrypt Certificate (LE) on your NethServer, and you can forget Certificate Issues in the future… :slight_smile:
I’m also a Mac user, and LE certs work great for Nextcloud (Adresses/Calendar/Files), Mail, Web and others.
No more SSL cert issues at all!
For LE, you do need a static IP, or at least a DynamicDNS Hostname.
These Infos are valid for NethServer 7 and also for NS8!
Hello Andy,
Thanks for the quick help. It worked like a charm.
Thank you very much.
Gottfried
Good to hear it’s working!
Please set this, as original poster, as it may help others here!
