Certificate and Onlyoffice
NethServer Version: 7.9your_version
Module: Onlyoffice document server
hi, all
My problem…
when the Let’s certificate update, all services work well but Onlyoffice doesen’t work.
I must restart nethserver and than all service works well. Can I restart only onlyoffice service?
Is there a command for this operation?
TK
This should restart/reconfigure everything needed:
signal-event nethserver-onlyoffice-update
This commad wasn’t good…
You are accessing that site on port 8082. Not sure if LE is accepting this port other then the official secure ports. If your certificate is generated by LE ofcourse.
Solved, I don’t have exclusive access to the firewall and someone opened a NAT on port 8082 that goes to another service…
Sorry
TK
