pike
(Michael Kicks)
October 11, 2019, 5:36pm
1
The evening brings a new error…
[root@ns76-01 ~]# yum update
* epel: pkg.adfinis-sygroup.ch
Resolving Dependencies
--> Running transaction check
---> Package certbot.noarch 0:0.36.0-1.el7 will be updated
---> Package certbot.noarch 0:0.38.0-1.el7 will be an update
---> Package python2-acme.noarch 0:0.36.0-1.el7 will be updated
---> Package python2-acme.noarch 0:0.38.0-1.el7 will be an update
---> Package python2-certbot.noarch 0:0.36.0-1.el7 will be updated
---> Package python2-certbot.noarch 0:0.38.0-1.el7 will be an update
--> Processing Dependency: python2-distro for package: python2-certbot-0.38.0-1. el7.noarch
---> Package python2-html2text.noarch 0:2016.9.19-1.el7 will be updated
--> Processing Dependency: html2text for package: po-debconf-1.0.20-5.el7.noarch
--> Processing Dependency: html2text for package: debhelper-11.4-2.el7.noarch
---> Package python2-html2text.noarch 0:2019.8.11-1.el7 will be an update
---> Package python2-distro.noarch 0:1.2.0-3.el7 will be installed
---> Package python3-html2text.noarch 0:2019.8.11-1.el7 will be installed
--> Processing Dependency: python(abi) = 3.6 for package: python3-html2text-2019 .8.11-1.el7.noarch
--> Processing Dependency: /usr/bin/python3.6 for package: python3-html2text-201 9.8.11-1.el7.noarch
Error: Package: python3-html2text-2019.8.11-1.el7.noarch (epel)
Requires: /usr/bin/python3.6
Requires: python(abi) = 3.6
Installed: python-2.7.5-80.el7_6.x86_64 (@ce-updates)
python(abi) = 2.7
python(abi) = 2.7
Available: python-2.7.5-76.el7.x86_64 (ce-base)
python(abi) = 2.7
python(abi) = 2.7
Available: python-2.7.5-77.el7_6.x86_64 (ce-updates)
python(abi) = 2.7
python(abi) = 2.7
Available: python34-3.4.10-2.el7.x86_64 (epel)
python(abi) = 3.4
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Maybe a simple yum install phyton36 could solve but… i don’t know if this can mess something else. Or even… need another repo?
mark_nl
(Mark Verlinde)
October 11, 2019, 6:02pm
2
this is odd, with CentOS/Rhel 7.7.1908 they finally realized python2 and 3 live happily among each other as-long-as you handle the shebangs well. On 7.7 we get python3 without the silly epel pyhton36 and scl for python3.
AFIAK this week nethserver switch to 7.7 so it should pull in the required dependency quite easily…
pike
(Michael Kicks)
October 14, 2019, 1:46pm
3
7.7 still not available via updates…
giacomo
(Giacomo Sanchietti)
October 14, 2019, 2:04pm
4
Thank you for reporting, I’m going to do some tests on it.
The updates will be available from tomorrow.
giacomo
October 14, 2019, 2:23pm
5
Sorry but I couldn’t reproduce the problem on a NS 7.7 and I never seen it on a NS 7.6.
I don’t have htmltotext installed in any of my machine.
Could you please check what is requiring it?
rpm -q --whatrequires python2-html2text
Also certbot doesn’t require python3 at all:
[root@test squid]# rpm -qR certbot
/bin/sh
/usr/sbin/restorecon
/usr/sbin/semanage
config(certbot) = 0.38.0-1.el7
python2-certbot = 0.38.0-1.el7
rpmlib(CompressedFileNames) <= 3.0.4-1
rpmlib(FileDigests) <= 4.6.0-1
rpmlib(PayloadFilesHavePrefix) <= 4.0-1
systemd
systemd
systemd
rpmlib(PayloadIsXz) <= 5.2-1
pike
(Michael Kicks)
October 14, 2019, 2:30pm
6
Alien…
[root@ns76-01 ~]# rpm -q --whatrequires python2-html2text
no package requires python2-html2text
[root@ns76-01 ~]# yum remove python2-html2text
---> Package python2-html2text.noarch 0:2016.9.19-1.el7 will be erased
---> Package debhelper.noarch 0:11.4-2.el7 will be erased
--> Processing Dependency: debhelper for package: alien-8.95-3.el7.noarch
---> Package po-debconf.noarch 0:1.0.20-5.el7 will be erased
---> Package alien.noarch 0:8.95-3.el7 will be erased
Dependencies Resolved
Package Arch Version Repository Size
Removing:
python2-html2text noarch 2016.9.19-1.el7 @epel 173 k
Removing for dependencies:
alien noarch 8.95-3.el7 @epel 223 k
debhelper noarch 11.4-2.el7 @epel 1.2 M
po-debconf noarch 1.0.20-5.el7 @epel 206 k
Transaction Summary
Remove 1 Package (+3 Dependent packages)
Installed size: 1.8 M
Is this ok [y/N]: y
Downloading packages:
Running transaction test
Transaction test succeeded
Running transaction
Erasing : alien-8.95-3.el7.noarch 1/4
Erasing : debhelper-11.4-2.el7.noarch 2/4
Erasing : po-debconf-1.0.20-5.el7.noarch 3/4
Erasing : python2-html2text-2016.9.19-1.el7.noarch 4/4
Verifying : debhelper-11.4-2.el7.noarch 1/4
Verifying : alien-8.95-3.el7.noarch 2/4
Verifying : python2-html2text-2016.9.19-1.el7.noarch 3/4
Verifying : po-debconf-1.0.20-5.el7.noarch 4/4
Removed:
Dependency Removed:
alien.noarch 0:8.95-3.el7 debhelper.noarch 0:11.4-2.el7
Complete!
I used it for Unifi controller setup… without removing it after
https://community.nethserver.org/t/install-unify-controller-on-nethserver-7/
