System: NS7, NethServer-Nextcloud, Collabora installed via Yum
I have Collabora installed and working.
In order to connect to the Collabora virtual host a valid cert is needed.
I have obtained a LE cert for the virtual host and manually copied the cert info into the virt host .conf.
As well as I can see neither ‘setprop loowsd Domain’ or ‘signal-event nethserver-collabora-update’ attaches a cert to the virt Collabora server.
My problem is this:
What is the correct procedure to attach a cert to this virt server noticing that the Collabora virt host is a system host and not visible in the web GUI.
Thanks for an excellent product
Best regards
