after rhel 7.8 rel
it seems that CR repos for l 7.8.2003 are populated for all supported platforms…
happy testing…
@quality_team @dev_team
after rhel 7.8 rel
happy testing…
The work is already going: https://github.com/NethServer/dev/issues/6118
I’ve found a bug, but I’m not really sure where to report it: https://twitter.com/gsanchietti/status/1248182904129290240
CentOS 7.8.2003 is out! https://lists.centos.org/pipermail/centos-announce/2020-April/035696.html
Now 7.8.2003 is served by mirrorlist.nethserver.org.
It is possible to upgrade a 7.7 to the development version of 7.8 with the following commands
yum update --enablerepo=nethserver-testing nethserver-subscription
signal-event software-repos-upgrade
It is possible to install nethserver 7.8.2003 (development) on CentOS 7.8 minimal (not tested)
yum install -y http://packages.nethserver.org/nethserver/7.8.2003/testing/x86_64/Packages/nethserver-release-7-16.1.g167ab8b.ns7.noarch.rpm
nethserver-install
great
tested on
tomorrow i will do some more test on ns7 with some modules installed…
thank you, and stay safe! ![]()
New commands are
The template-custom is not required any more.
been running ns 7.8 heavily for the past 15 hours and it works great.
Yes, by heavily i really mean heavily
RC1 is ready to be tested http://packages.nethserver.org/nethserver-7.8.2003-rc1-x86_64.iso
