Captive Portal (coovachilli)
(Tohid Tamboli) #1
I want to configure captive portal for neth.
And can i integrate it with nethserver?
link,documentation will go.
in short how to install coovachilli in nethserver?
A captive portal with voucher for Nethserver
(Filippo Carletti) #2
Nethesis, the company sponsoring NethServer has a commercial product partly based on coovachilli running on NethServer, but using a closed website for administration.
I looked in the developer site (dev.nethserver.org) and found a coovachilli category with no issues.
Let me check what we have, on Monday.
(Tohid Tamboli) #3
I to found coovachili in repository but Its not available in software center?
http://dev.nethserver.org/projects/nethserver/repository/coova-chilli
Captive Portal on Nethserver
(Giacomo Sanchietti) #4
The package is available in nethserver-base repository but without any web interface.
To install the package:
yum install coova-chilli
(Tohid Tamboli) #5
Coova-chilli will be handled manullay right?
(Giacomo Sanchietti) #6
Right, you can manually change the configuration: no db or templates have been implemented.
(Giovanni Bezicheri) #7
The standard package relies on CoovaChilli cloud services that i think are dismissed. But you can reconfigure it by yourself to point it to a local radius server.
