Can't install NethServer 7 ISO on Hyper-V
same virtual machine config with 6.7 iso
@cronopio
What hard drive controller emulator do you use ?
http://www.hyper-v-mart.com/Howto/Install_CentOS_5_VM_Step_by_Step.aspx
@Nas : 1st generation virtual machine!! :sob:
why do you think that you do not need additioanal LINUX drivers for HYPER-V ?
I will try with my Hyper-v server
I think for now you can not use the second generation, look here:
Bug 1192030 - Workstation LiveISO refuses to boot on Hyper-V Generation 2 VM
You could try by creating a VM first generation, and then utilize the VHD created with a second-generation VM.
Ciao
Enzo
Read this article:
http://www.linuxquestions.org/questions/linux-software-2/rhel7-installation-fails-dev-root-does-not-exist-4175515886/
They speak of RH7.
They solved the problem by recreating the ISO to support UEFI boot.
Good luck :wink:
