I tried to get a nethserver like a gateway with two NICs, eth0 lan(green) and eth1 Internet(red), this second don’t let me choose between green or red or any other, i made the change with
db networks set eth1 ethernet role red
I set a static Ip but still don’t work. Thanks for your help.
Is this a fresh installation? Were you able to download all the updates and install all the software components you require, including web proxy and web filter?
