Can't apply OpenVPN settings V8.2
Hi, as i stated in the title, i am not able to save any changes to the OpenVPN configuration.
In the WEBUI, when i click “apply”, i get the following errors in the browser’s console:
TypeError: e is undefined
    hs https://192.168.77.50:9090/assets/index-215fb8ae.js:1577
    ln https://192.168.77.50:9090/assets/OpenvpnRoadWarriorView-50f20440.js:1
    sn https://192.168.77.50:9090/assets/OpenvpnRoadWarriorView-50f20440.js:1
    25 https://192.168.77.50:9090/assets/OpenvpnRoadWarriorView-50f20440.js:1
    Kr https://192.168.77.50:9090/assets/index-215fb8ae.js:13
    vn https://192.168.77.50:9090/assets/index-215fb8ae.js:13
    n https://192.168.77.50:9090/assets/index-215fb8ae.js:17
index-215fb8ae.js:13:605
I was wondering if someone else had the same problem
Hi, can you attach a screenshot of the configuration fields in the side drawer?
Hi, as you can see in the screenshot attached, i’ve added a network (the one highlighted in yellow) to an existing vpn that was already working, and after adding it the “save” (salva) button doesn’t do anything.
If i rollback to version 8.1 (i’m on 8.2 now), the bug gets fixed.
It has happened on more than 2 firewalls already.
Thanks in advance.
Please attach the upper part of the drawer too. Be sure to include Dynamic range IP start/end fields
Dynamic range IP
You can reserve IP addresses to OpenVPN accounts outside the following range.
this?
