Having a good installation guide for proxmox would be awesome!
p.s. Rafael great to see you back!
Ok, Iâll do it as soon as possible!
On Proxmox (3.4) interface, you create the new VM, and start the process.
After a few seconds, the new VM will be created. Yo can start it, and with the VNC (integrated on Proxmox) start the installation process.
Some Notes:
a) we use virtio drivers for NIC and hard disk, they work good.
b) You can add disks and networks interfaces on any time, hotplug or not, according to your needs.
c) The process on Proxmox 4.x is very similar.
Well⊠if any of you need any help, just ask!
Cheers
Asrix
@Asrix, your proxmox installation guide has been added to the wiki.
Feel free to add any other information you think can be useful.
Hi, I have a question regarding this. So you want to set Nethserver under proxmox. Because Proxmox is booted before Nethserver, it canât get an IP assigned to it. So I presume you have to assign an IP to Proxmox (static IP) for your network to see it? Iâm trying to see how this would work and what some of you did.
Hi Patrick
Proxmox needs a static IP assigned. I always use IPs 61, 62 etc (If I have more than one Proxmox).
DHCP is done either by my OPNsense Firewall or the NethServer. These can be in Proxmox, no issues.
Proxmox needs a reboot maybe once a year due to updates, noot more.
Even if Iâm accessing the Network via VPN, and the Router/Firewall is in Proxmox, I can access it again in 3-5 Minutes using VPN -when I need to reboot Proxmox.
Hey Andy, thanks for the reply. So lets say Nethserver is my DHCP server and it is running under Proxmox. I have a class C network using 192.168.20.x. I assign Proxmox some IP, lets say 192.168.20.61 (and also reserving it in Nethserver) then I should be able to see it on the network no problem if I understood correctly?
Hi Patrick
Yes, thatâs right.
See the first sketch here:
https://wiki.nethserver.org/doku.php?id=userguide:nethserver_and_proxmox
I did not draw in any PCs, Notebooks or Tablets in this sketch, but essentially, thatâs how my home Network looks likeâŠ
NethServer, running in Proxmox, does AD, Files, Mail, NextCloud, Zabbix, etc.
DHCP and DNS are handled by OPNsense, the Nethserver is second DNS with all local devises entered in both.
It also works if NethServer is your Firewall and running in Proxmox, or you use OPNsense in Proxmox as your Firewall.
BTW: That very Network you have, 192.168.20.x/24, is also used by a client of mine, a Doctor.
They have two Proxmox running, DHCP and DNS is done by NethServer, running in Proxmox.
Both Proxmox are running in a fast migration Cluster, one is actually the old VMWare ESXi server, reinstalled with Proxmox, and the main, new HP server.
That is very good to know. Iâm still debating if to build a 2U Server Chassis with a 3700X with Proxmox, Nethserver and 1 or 2 VMS or just run Nethserver with a 3300X. Iâm considering my options but for sure if I put a higher end CPU on that machine, I donât want to just waste the power (that is a 3700X is way too much muscles for Nethserver)
If you have a PC with 6-8 GB RAM & a 500 GB harddisk or SSD, try building a test Proxmox to test / gain experience / estimate requirements⊠This can already run a complete home network!
The Instal of proxmox takes around 20-30 mins, NethServer an additional 30. Add in an hour for copying ISO Images and stuff to the right places, and youâre ready to go. The installed VMs can be migrated later to your newer hardware, if all goes as you expectedâŠ
That is the problem, I need to get the hardware so I canât test otherwise I would have done it. So I have go by what peopleâs experience, advices and documentation.
Thinking and planning things through is always a good premiseâŠ
But one can always overdo things:
5 years ago, a good friend of mine, an american married to a swiss, working at a major swiss bank as programmer started âevaluatingâ buying a notebook.
This took over 9 months!
He finally came to his senses when I told the time he spent evaluating, not counting my time for the plenty of advise asked, amounted - at his pay scale - to well over twenty grand! (Enough to buy 5 Notebooks of the top end type!). And he still hadnât got a newer notebook!
He bought a Macbook the next day!
Proxmox will run on any standard box. If you are unsure, just pick up a cheap server that is obsolete from a datacenter. I see youâre from Canada. Just as an example: http://www.deltaserverstore.com/dell-1950.html
You could even install proxmox on an old desktop. Make sure it has at least 4GB RAM and you are good to go for some basic testing. I did this in order to migrate from a default KVM server to proxmox and re-use the old KVM server.
Then install Proxmox on that server (or old desktop). It is as easy as installing any distribution. Proxmox base is Debian, so it shouldnât be that unfamiliar to install. And there is a nice graphical installer to guide you. Also the proxmox installation instruction is quite extensive.
BTW, my strong suggestion would be to go for a Virtualization layer and not to install (any Server OS) NethServer directly on the server. It gives so much more flexibility. I am sure, once you have used this for a while, you will never go back to bare metal installs of an OS.
/edit: extra info on requirements for proxmox: System Requirements - Proxmox VE
Minimum Requirements, for Evaluation
These minimum requirements are for evaluation purposes only and should not be used in production.
CPU: 64bit (Intel EMT64 or AMD64)
Intel VT/AMD-V capable CPU/Mainboard for KVM full virtualization support
RAM: 1 GB RAM, plus additional RAM used for guests
Hard drive
One NIC
This means you can in fact install on an old desktop to evaluate.
