Hello
i am new into Nethserver and so far really like it. Fast and intuitive, not with such a children UI like i.e. Smartermail which is influenced by MS because they think its better when you have flat design, with too big text that hurts in eyes.
For the moment i am focusing on calendar and Outlook. I tried Webtop and found that there are 2 calendars listed on each user. The normal one and one called “webtop”. Users are confused if they see multiple calendars, is there a technical reason for this? It seems also the “normal one” cannot be synchronized across multiple devices.
Was also wondering if it makes a difference if i use SOGo or Webtop. Is difference only in Webclient or on the backend too? I think both are using Z-Push for Activesync functionality right? But with SOGo i couldnt remember seeing 2 calendars. Is it possible with SOGo to also share a calendar?
And what about contacts? Any way to have common contacts?
I know that Nethserver doesnt focus on Outlook but you know users dont want anything else and i couldnt find any better product in this regards so far.
Tom
