After updating work well for a while, but after ruling out the internet. I had to make downgrade to regain Internet
Only it happens to me or any of you happened to them?
regards
It sounds strange. Version 2.7.0-1 still has bug #3232. Hotfix release 2.7.0-2 finally fixes the error. Perhaps you didn’t hit the bug, but some other problem and the downgrade had fixed it as side-effect of the firewall restart.
Could you upgrade to the latest version again?
I’m trying again, but since the data was updated IP address does not appear
Regards
