Block samba users from copying files from mapped folders
I need to share a folder where the files could not be downloaded to the computer, only read by the user, It is possible to create this limitation in the folders mapped by the Nethserver 7 file server
Not with samba, AFAIK.
You can restrict access permissions to deny/allow access to required users.
You can search for some kind of online file viewer / nextcloud plugin to restrict it more, but in most cases the file is downloaded (in one way or another, by the broswer in temp files, full or by parts, etc.), can be screen-shooted…
Beyond samba file server, there are solutions, like the ones some sites do for online books, for instance, or a pdf.js viewer/converter, adobe proprietary solutions…
If I recall correctly @greavette had a similar request (but for nextcloud). Maybe he can bring some light to the matter.
