Hello I want to block anydesk }, how I can do that.? Thanx
I am sure you could have found this info on the anydesk website: https://support.anydesk.com/Firewall
You could block the ports and url/IP listed. Just don’t block ports 80 and 443 since those are default http and https ports.
According to the anydesk manual it uses port 7070 for direct connections, so that port you might want to block too. Be aware that the port can be changed on the client in the client settings.
Hello were I can block the port…?
Here is some reading so you can find out. https://docs.nethserver.org/en/v7/firewall.html
