[BETA] ns8-ssh-access-manager — SSH key audit and lifecycle management for NethServer 8
root@d1:~# add-module ghcr.io/stephdl/sam:0.0.1-dev.6
new version
  1. I installed the new release.
  2. I installed a new deban13 server for testing
  3. I installed the sudo package
  4. I granted alice ( Fine-grained sudoers delegation)
  5. i validated granting well
  6. I generated in 1Password a publik ssh-ed25519
  7. I provide this key in SAM
    … and got an error
Am I wrong?
log
2026-04-29T15:53:33+02:00 [1:sam1:sam-app] 2026-04-29 13:53:33,392 INFO 127.0.0.1 - - [29/Apr/2026 13:53:33] “e[35me[1mPOST /api/access/deploy HTTP/1.0e[0m” 500 -
2026-04-29T15:53:33+02:00 [1:sam1:sam-app] 10.0.2.100 - - [29/Apr/2026:13:53:33 +0000] “POST /api/access/deploy HTTP/1.1” 500 34 “ssh-access-manager” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/26.4 Safari/605.1.15”
2026-04-29T15:55:01+02:00 [1:sam1:sam-app] 2026-04-29 13:55:01,650 INFO Connected (version 2.0, client OpenSSH_10.0p2)
2026-04-29T15:55:01+02:00 [1:sam1:sam-app] expire.py: 0 warnings sent, 0 keys expired
2026-04-29T15:55:01+02:00 [1:sam1:sam-app] 2026-04-29 13:55:01,685 INFO Authentication (publickey) failed.
2026-04-29T15:55:01+02:00 [1:sam1:sam-app] 2026-04-29 13:55:01,703 INFO [CRITICAL] [ssh-access-manager] Scan failed on 1debian
2026-04-29T15:55:03+02:00 [1:sam1:sam-app] FAILED 1debian: Authentication failed.
2026-04-29T15:56:36+02:00 [1:sam1:sam-app] 2026-04-29 13:56:36.711 UTC [56] LOG: checkpoint starting: time
2026-04-29T15:56:37+02:00 [1:sam1:sam-app] 2026-04-29 13:56:37.370 UTC [56] LOG: checkpoint complete: wrote 6 buffers (0.0%), wrote 1 SLRU buffers; 0 WAL file(s) added, 0 removed, 0 recycled; write=0.603 s, sync=0.027 s, total=0.659 s; sync files=7, longest=0.007 s, average=0.004 s; distance=5 kB, estimate=154 kB; lsn=0/1C248B0, redo lsn=0/1C24858
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] 2026-04-29 13:56:59,206 INFO Connected (version 2.0, client OpenSSH_10.0p2)
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] 2026-04-29 13:56:59,251 INFO Authentication (publickey) failed.
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] 2026-04-29 13:56:59,253 ERROR deploy_key failed
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] Traceback (most recent call last):
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] File “/app/app/web.py”, line 631, in api_deploy_key
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] result = actions.deploy_key(
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] ^^^^^^^^^^^^^^^^^^^
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] File “/app/app/actions.py”, line 502, in deploy_key
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] ssh.ensure_scripts(hostname, server[“id”], server[“ip_address”])
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] File “/app/app/ssh.py”, line 253, in ensure_scripts
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] client = _connect(ip)
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] File “/app/app/ssh.py”, line 216, in _connect
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] client.connect(hostname=ip, username=SSH_USER, key_filename=COLLECTOR_KEY, timeout=15)
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] File “/usr/lib/python3.12/site-packages/paramiko/client.py”, line 483, in connect
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] self._auth(
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] File “/usr/lib/python3.12/site-packages/paramiko/client.py”, line 814, in _auth
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] raise saved_exception
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] File “/usr/lib/python3.12/site-packages/paramiko/client.py”, line 731, in _auth
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] self._transport.auth_publickey(username, key)
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] File “/usr/lib/python3.12/site-packages/paramiko/transport.py”, line 1703, in auth_publickey
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] return self.auth_handler.wait_for_response(my_event)
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] File “/usr/lib/python3.12/site-packages/paramiko/auth_handler.py”, line 263, in wait_for_response
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] raise e
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] paramiko.ssh_exception.AuthenticationException: Authentication failed.
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] 2026-04-29 13:56:59,260 INFO 127.0.0.1 - - [29/Apr/2026 13:56:59] “e[35me[1mPOST /api/access/deploy HTTP/1.0e[0m” 500 -
2026-04-29T15:56:59+02:00 [1:sam1:sam-app] 10.0.2.100 - - [29/Apr/2026:13:56:59 +0000] “POST /api/access/deploy HTTP/1.1” 500 34 “ssh-access-manager” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/26.4 Safari/605.1.15”
Ps.: I also added PubkeyAuthentication yes in /etc/ssh/sshd_config and restarted ssh
Ps2.:I also added the key in /home/audit-collector/.ssh/authorized_keys
Ps3.: Perhaps I need to provision the remote server manually?
../bin/provision-server --hostname debian.home.mydomain.de --ip 192.168.3.27 --user root --env lab --os debian
Unfortunately, I can’t access the environment:
root@daho-ns8:~# runagent -m sam1 podman exec -ti sam-app bash
Error: crun: executable file `bash` not found in $PATH: No such file or directory: OCI runtime attempted to invoke a command that was not found
root@daho-ns8:~#
I am providing a new way for the onboarding, more simple
add-module ghcr.io/stephdl/sam:0.0.1-dev.7 1
new way to provision a server, either you do not trust me and you can provision the server manually
you run a CLI where you give the password on the cli
or if you trust me you can do it in the UI, the password is not saved in database it is only to authenticate, create the user and give the key based access to sam
Full verification complete. The SSH password is never stored — not in the database, not in logs.
add_server() (line 638–675)
  • ssh_password is received as a parameter and passed only to ssh.provision_server() (line 655)
  • The INSERT INTO servers (line 656–659) contains only: hostname, ip_address, environment, os_family, ssh_port
  • Both INSERT INTO audit_log entries (lines 661–673) record: hostname, ssh_user, ssh_port — no ssh_password
provision_server() (line 678–702)
  • ssh_password is passed only to ssh.provision_server() (line 686)
  • The UPDATE servers (line 688–690) updates only ssh_port
  • The audit_log entry (lines 692–701) records: hostname, ssh_user, ssh_port — no ssh_password
SQL schema (servers table)
The table has no ssh_password column — it cannot be stored accidentally. Columns are: id, hostname, ip_address, ssh_port, os_family, os_version, environment,
is_active.
The SSH password is ephemeral: held in memory only for the duration of the paramiko connection, then discarded.
in short, we have several way to provision a remote server see
  • support of non standard port
  • debug added whatch out the sshd service log on remote and local host
  • banner of warnings inside the UI
Like Tracy Chapman sang in Crossroads, SAM is standing at a crossroads.
I think I built something that went far beyond the original game I had in mind. At first, it was almost a way to quiet down the impostor syndrome that still follows me, even after years of development and experience. But now I’m starting to wonder where this project could really go.
Maybe SAM could evolve into something deeper: acting as a certificate authority to deliver temporary server access through certificates, managing time-limited trust instead of static credentials. It could even handle privileged access by automatically placing created users into groups like sudoers, wheel, or sudo when needed.
Or perhaps SAM could become a real bastion host, a secure entry point allowing controlled jumps between servers, centralizing authentication, auditing, and access flows. And honestly, both directions could coexist and be developed together: certificate-based identity and privileged access management on one side, secure server hopping and infrastructure control on the other.
The next versions are already coming with many fixes, improvements, and new features. From the beginning, SAM was designed to remain a standalone project, independent and usable on its own, even if I also plan to offer an integration with NethServer 8.
Right now I feel like I’m exploring unknown territory, somewhere between technical curiosity and introspection, trying to understand not only what SAM could become, but also what kind of builder I want to become along the way.
It’s great to see that it’s not just a case of fleshing out the old framework, but that a dynamic new development is taking place here.
I’m curious to see where this takes you – and us.
Just a spontaneous thought, without being able to judge how realistic it is – perhaps you could bear in mind from the outset that, when using agent-based AI, access to systems must also be provided for these agents. If no API is available, the only option is often to provide (root) credentials, which naturally causes unease, even if I have configured my agents so that private and other sensitive information never leaves the locally running agents and must not be transmitted to the LLMs.
But who knows what might happen.
In that respect, stricter management of access for agents would be a sensible addition, especially as the agent-based AI train is leaving the station very quickly and is unstoppable.
…whether you like it or not, whether you use it yourself or not.
The less NS8 supports this trend, the less attractive the platform is likely to become in the long term. Vice versa.
So you are in the process of developing a tool that will be important for the future.
Defining sudo permissions in a very granular way is technically possible, and I already evaluated that approach. However, it is also much more verbose and constraining than simply pushing a user into a group like sudo or wheel. Still, from a technical perspective, it can absolutely be done.
The train is already in motion, and AI has profoundly changed software development — and tomorrow it will profoundly change our society as well.
I’m part of the generation that learned development from books because the solution was hidden somewhere inside 800 pages. Then Google arrived and allowed us to search for answers instantly. After that came Stack Overflow. And now we are reaching a point where a single person can build SaaS solutions in days or weeks that previously required entire teams working for months.
But there is also a danger in that acceleration.
Doing bad development ten times faster is still bad development — just at an exponential scale. That is why strict CI pipelines, automated code reviews using modern tooling, upstream research on best practices, and security-oriented design are becoming absolutely essential if we want something secure and maintainable.
Because making something merely functional has become incredibly fast :smiley:
