BackupPC 4 Web Interface Not Found on NethServer 8 (NS8)
Module: Backuppc
Hello everyone,
I installed BackupPC 4 on my NethServer 8 using the command line module: add-module ghcr.io/stephdl/backuppc:1.0.0-dev.7.
I configured the required FQDN via the settings on NS8 GUI.
The Problem:
The FQDN link appears in the NS8 dashboard, but when accessed, the BackupPC web interface does not load.
Is this due to a misconfiguration of the HTTP Route on NethServer 8?
What steps should I take to correctly link the configured FQDN to the running BackupPC service on NethServer 8 and resolve this access issue?
Are you here Mr. @stephdl ? :slight_smile:
Thank you in advance!
Hello
Configure first nethforge I think
Yes, after enabling NethForge in the Software repositories you can install the most recent BackupPC 1.1.0 from Software Center.
