Backup stops with errors
Module: backup
Today i faced a new Problem what was working smooth in the past. The backup on a nas works for a time and now it stops showing a message that it was not possible to finish it. I see that some data is progressed but not all.
with an older installation everything works perfectly… just as an information.
grafik
Look at the Logs page, the backup procedure should print the error reason in the application log.
also the logs dont work
and one Hardisk is full too
Festplatte 4
Nutzung 100%
Gerät/dev/mapper/rl-home
Mount point/home
Dateisystemxfs
Gesamt23.09 GiB
verwendet23.09 GiB
Frei32 KiB
now i am not able to reach the UI in general, so i will again start from the beginning… it is… difficult to understand what happens…
I guess you need to assign more disk space.
From System requirements — NS8 documentation
Minimum hardware requirements for a single node installation:
40GB Solid-state drive
Good Morning Markus, i installed a new VM with NS8 right now. Also the last had 100 Gig the Harddisk,what i spoke about is one of the Partitions what NS8 did. Now i can Backup the new NS8, the Logs are working fine, but again one Partition is more or less full. Maybe this
makes it more clear. Could it be that, when i am starting to install things like Crowdsec and other Things a Problem will be initiated ?
I think this is because of Rocky Linux automatic partitioning at installation.
You could choose custom partitioning at installation or resize it later.
okay… what would be o good size then? did not read about it somewhere…
Most data are kept inside /home.
Take a look here for more info: Disk usage — NS8 documentation
