Backup on USB-HD fail
Yes - that is our plan … like it was possible on NS7
OK, I need to test it, I’ll report my findings.
It’s possible to rotate more disks with one local backup but the rclone-webdav service needs to be stopped when disconnecting a USB disk and connecting another one and then the rclone-webdav service needs to be started again to mount the other disk.
Please check your disks using lsblk -f
In my case I have one disk sda for Nethserver, so a plugged USB disk gets sdb.
Stop the rclone-webdav service.
systemctl stop rclone-webdav.service
Remove backup00 and probably other backup01…XX volumes:
podman volume rm backup00
Recreate backup00, but instead of a disk ID I used /dev/sdb (sdb is the USB disk)
podman volume create
       --label org.nethserver.role=backup
       --opt=device=/dev/sdb
       --opt=o=noatime
       backup00
Start the rclone-webdav.service
systemctl start rclone-webdav.service
Now one disk is mounted and backups to it should just work.
To use another disk:
Stop the rclone-webdav service:
Disconnect the USB disk and connect another one.
Start the rclone-webdav service:
Now the backup to the new disk should work.
Thank you very much - I will try it this next weekend.
