Backup not found
Another question :grimacing:
I see no backups available after pressing the Backup button
Is this correct or am i doing something wrong ?
This is still related to the community subscription which still does not have access to the remote server where backups are stored.
I’d label this as a bug, but you need to wait a bit: the fix will depend on how we are going to shape the subscription plan.
Ok. No problem.
After the update to 1.0.1 the backup files are visible in the UI
Only it need a bit updated translation :grin:
